A 3 link with bushing linkages?
unclear if that is a rod end but it kinda looks like not, very well could be though.
it would be better if I had already made [the subdivision for those kinda boards then you could talk all about all of them.
Ok making now.](Leaning Wheel Trucks, Street Focus. Lean board, BMW Streetcarver and Flexboardz... - #2 by Fosterqc)
funny design when you compress the hanger the extra bushing prevents the forces from going into the bs bushings.
says the pivot is larger which reminds me of this
gigantic pivot, better fit I presume.
Just saw this board for sale. Anyone tried swelltech? I actually really like the deck, and that front baseplates cool, but im not so sure about the actual performance. Those springs look like theyre just waiting to fly out.
Channel RKP?
Donât know if these count but new/interesting to me. GBombs 6 degree trucks
Yeah I used to have a set of those on a push board, but these Chinese ones seem a bit different, plus it looks like a caliber 2 axle profile (meaning these could actually easily be used for esk8)
Wouldnât they run into the same issues Trampa trucks and L-Faster trucks have of no damping with springs? Would be cool if they managed to take shockblocks or hypertruck bushings though.
The springs are super tight, so they gave about the same give as a bushing setup with stock bushings
itâs like ackerman-style caster trucks or something.
I bet itâs terrible under load.
in construction style yes but not in function.
This is like a spherical bearing formed from attaching two bearings together at 90 degrees. Then the small links from the SRB NKP.
That looks so bad.
Might be the worst truck Iâve seen listed for sale.
Also, fun fact, might be infringing on Other Planets truck patent (if its still active), which I believe heavily emphasized the slot.
Seismic were designed to pump, so you donât want to lose the energy of the turn to dampeners.
https://imgur.com/a/WVa95f9#mp2vQHQ
Truck geometry.
I would like to see some 3 link trucks that could be easily retrofit onto regular boards.
