All terrain pneumatic wheels
Hey, Any recommendations on AT pneumatic wheels which fit the 218mm TB trucks? (with minimal to zero amount of dremel cutting \ sanding needed)
Pretty much anything evolve style will work fine. Those take standard skate bearings. You’d want something with bolt on pulleys for that since you dont have stepped axles for the bigger bearings
These should work pretty well for you.
Thank you for your help!
It’s not so much the wheels as the pulleys that you’ll have to watch out for mostly. From my experience, press fit pulleys for at Wheels are meant for longer axles and double Kingpin trucks.
Update:
Got the AT wheels, it did’nt fit.
Dremel’ed my through the trucks and exposed another 10-15mm of axle, and now it fits perfectly.
