Molicel date codes batch year
Search terms: weld center of cell, do not weld, avoid areas, internal, negative can, diameter, spot weld
@Boardnamics can you confirm this? Need to redesign my motor mounts because they don’t properly fit the precision profile. My profile measurements are slightly different.
It is correct.
Why is the height 18.31 instead of a nice round 18 to make the bounding box square?
18.31mm is stronger than 18.00mm
And 19x19 is extra strong
Would need all new clamps for mounts n gear drives. I feel like its a pretty insignificant issue.
Definitely not an issue, but usually numbers like that are rounded and I’m curious what the justification was
Its not imperial and it’s not a 40° slope
They’re an interpolation of caliber profile. Caliber is 18mm wide, but the arch is such that an 18mm square wouldn’t quite fit inside.
This cross section is maximized.
This thread helped me today. Thanks @frame
TRAMPA MOUNTING PATTERN
TRAMPA DECK HOLE PATTERN
INFINITY TRUCK MOUNTING PATTERN
TRAMPA TRUCK DIMENSIONS
TRAMPA HOLE PATTERN
KALY TRUCK DIMENSIONS
KALY MOUNTING PATTERN
KALY HOLE PATTERN
for google to scrape
@frame I still use this reference. Thanks again dude!
