A Guide to Gears: 8 Gear types explained
Read this lovely article laying out the different gear drive transmissions and a basic description of each. Thought it’d be a nice visual resource to have here so credit goes to Chris Young.
1. Spur gears
Spur gears are one of the most common types of gear out there. They have cylindrical pitch surfaces and belong to the parallel shaft gear group. They have a tooth line that is straight and parallel to the shaft.
Spur gears are commonly used because they can be relatively easily produced while achieving a high performance accuracy. The larger of the meshing pair is called the gear (pictured above) and the smaller one is called the pinion. They are typically used to increase or decrease torque in machines such as washing machines, clothes dryers, screwdrivers, windup alarm clocks, and blenders.
2. Helical gears
Similarly to spur gears, helical gears are used with parallel shafts. They are also cyclindrical gears with winding tooth lines. However, they are a definite improvement in terms of design over the spur gear. Unlike spur gears the leading edges of the teeth on helical gears are not parallel to the axis of rotation — instead, they are set at an angle.
Anim_engrenages_helicoidaux
This smooth teeth meshing means that the gears can transmit higher loads and are quieter than spur gears, which can be noisy at higher speeds. As these gears create thrust force in the axial direction, they require the use of thrust bearings. They are used in machines such as elevators and in factory automation.
3. Bevel gears
Bevel gears have the appearance of a cone that has had its top cut off. Within the bevel gear family, there are several different subsets, including helical bevel gears, straight bevel gears, spiral bevel gears, and miter bevel gears.
Bevel gears are used to transmit force between two shafts which intersect at a specific point. They are used in differential drives, such as those on a cornering automobile, as they can transmit power to two axles spinning at different speeds.
4. Spiral bevel gears
Spiral bevel gears are bevel gears that have curved tooth lines. Similarly to helical gears when compared to spur gears, the curvature allows for a higher tooth contact ratio, meaning that spiral bevel gears are more efficient than the standard bevel gear; they are stronger, less noisy, and vibrate less.
Why have spiral bevel gears not completely displaced the use of standard bevel gears you ask? Spiral bevel gears are harder to produce and, in some uses, they can also create unwanted thrust in axial directions, due to the curved teeth.
5. Worm gears
The “worm” of the worm gear refers to a screw shape cut into a shaft that the mating gear, or worm wheel, is attached to. Due to sliding contact of the gear surfaces a hard material is generally used for the worm, so as to reduce friction. Though the sliding contact means that worm gears aren’t incredibly efficient, their rotation is very smooth and quiet. As such, they are often used for industrial applications, heavy equipment, and sometimes consumer goods.
Worm gears provide very high reduction ratios and are often self-locking, as they cannot function in the reverse direction. This inherent feature makes them a safe option to use in certain types of machinery. A common example of a self-locking worm gear is the machine tuning head found on many string instruments, including the guitar.
6. Crown gears
Crown gears, also known as contrate gears, are a type of bevel gear whose teeth project at right angles to the plane of the wheel. This makes the teeth resemble the points of a crown, giving the gear its name. Unlike conical bevel gears, crown gears are cylindrical. They can either be paired with other bevel gears or spur gears, depending on the tooth design.
Crown_gear
Crown gears are typically used for applications where low noise-emitting gears are required. A crown gear used with a rack’s interlocking clogs allows the gear to roll along with the rack even if it has to go uphill or sideways. They are used for trains on uphill tracks, rollercoasters, locking doors on tracks, and car steering wheels.
7. Sun and planet gears
We probably don’t have to tell you why the sun and planet gear is called the way it is. The motion of its orbit-imitating flywheel allows the sun and planet gear to convert reciprocating motion into rotary motion. That’s why James Watt used it in his early steam engines.
Sun_and_planet_gears
In the illustration above, the sun is yellow, the planet is red, while the reciprocating arm is blue, the flywheel is green and the driveshaft gray. Sun and planet gears are an example of epicyclic gearing, or planet gearing, in which the center of one gear revolves around the center of another. They are used on anything from pencil sharpeners to locomotive engines.
Planetary gearboxes generally have single or two-gear stages for reduction ratios ranging from 3:1 to 100:1
8. Cycloidal gearboxes
Cycloidal gearboxes or reducers consist of four basic components: a high-speed input shaft, a single or compound cycloidal cam, cam followers or rollers, and a slow-speed output shaft. The input shaft attaches to an eccentric drive member that induces eccentric rotation of the cycloidal cam. In compound reducers, the first track of the cycloidal cam lobes engages cam followers in the housing. Cylindrical cam followers act as teeth on the internal gear, and the number of cam followers exceeds the number of cam lobes. The second track of compound cam lobes engages with cam followers on the output shaft and transforms the cam’s eccentric rotation into concentric rotation of the output shaft, thus increasing torque and reducing speed.
395bb7c663c6a0658da2a877e2bbf2a8
Compound cycloidal gearboxes offer ratios ranging from as low as 10:1 to 300:1 without stacking stages, as in standard planetary gearboxes.
Original Article
I still dream of the planitary geared hubmotor.
Hell yeah, I have full faith in you :stuck_out_tongue_winking_eye:
The worm gear would look really cool on an esk8 if the threaded pinion rod came straight out of the shaft. Not super efficient though based on contact points.
Planetary seems like the most moving parts in the smallest form factor but I’m no expert.
Someone made one im like 99% sure. Seent it on the builders forum
yes, they were called stary boards, kickstarter fraud, they sucked, went belly up. Motor was super noisy. Never delivered, End chapter
Now we need a good one
What’s the benefits of planetary for eskates?
Not eskates. Hub motors. you have a gearing ratio bigger then 1:1.
Ahh the idea is to assist with the weak torque of hub motors?
E-Bike Hub Motors come with gearing sometimes.
Are they planetary gear sets?
just did a battery replacement for a guy who had a baja knockoff, said he got the board for $1500 directly from china.
it had the baja style suspension but had rather noisy planetary hub motors. It was pretty slow, but it was also 4WD and a really clean build since there was no transmission or drive shaft stuff to deal with outside of the hubs.
Cool. Think problem is that most planetary gears are straight cut cause its effin expensive to make custom cog-wheels that are helical. Have yet to see/heard how noisy a helical planitary gear drive is
Yeah, shame on that, would be really cool
But they are dead silent, lots, if not most, of automotive automatic gearbox are helical planetary
It’s pretty well established knowledge that this is just not true; hub motors when built correctly have plenty of torque. What they don’t don’t always have is ride comfort.
Im pretty sure Jay Boston tried one of those boards out recently
He seemed like he liked it, but that’s to be expected with youtube reviewers I guess.
very nice.
I recently saw @klaus79856’s buddy rocking a cycloidal gear drive on his e-bike. Never saw one before, but I think it’s worth mentioning in this thread. Apparently capable of a very wide rang of gear reductions
Why planetary hub motor? In hub motors the wheel rests directly on the motor can; if you had a gear drive in there, you’d need an outer can layer.
Planetary gears would be absolutely perfect for direct drive though :heart_eyes:
has anyone tried making a harmonic drive work on esk8?
I wonder if that is still a flavor of planetary gear just based on gear interlacing being concentric. Very cool visualization to see, I’ll add it.
https://www.machinedesign.com/news/article/21829580/comparing-cycloidal-and-planetary-gearboxes
I’ll read up first lol
Wow, cycloidal MINIMUM reduction is 10:1 max is 300:1.
yeah, I think the complexity is a couple notches above a ordinary planetary gear. I could watch that gif all day trying to figure it out while tripping out on that motion.
