Hello,
following an accident with my 6384 190kv motor, can you tell me each color of wire that corresponds to the connection, in order to be able to re-solder them.
Thank you for your help
Hello,
Flipsky 6384 190kv
I only have the 6374 but i would assume they are the same?
No guarantee and i take no responsibility.
Sure, placement is different but color should probably be the same. E: no markings, hmm
Yes, but I have no marking on the circuit board. (seen from below)
black is ground, red is 5v and white tends to be temperature. but no guaranty like. you can also follow the pcb tracers, the middle contact on a hall sensor is the signal from it
I made a request to flipsky, maybe …
Thanks
