Looks like they are about the same length, but the enertion one has more adjustment and isn’t at a fixed angle
Okay cool, where are you supposed to get them?
@deckoz @ZachTetra we still have some 50mm mounts. They are pretty short. Shorter than standard. They are 21mm bolt to bolt though. Too many different mounting patterns for 50mm.
Forgot i posted a link earlier.
I’d try the @torqueboards ones tho.
I only went with these because i traded parts for them. Otherwise i was gonna try TB ones next.
I measured the Racerstar bolts at 26.5mm center-to-center in case anyone is wondering
The hole to hole on the edge of the square?
In theory it should be 1.4142*(38mm/2)=26.87mm
The orthogonal measurement, not the diagonal.
If the resistance is doubled the heating will be doubled, for a given acceleration.
