Enjoy , it looks comlicated first but in fact is really simple .
You will not loose the torque because these motors have a huge amount already.
Any progress ?
Those new hubs look dope!
What’s the topspeed?
Very nice! Do you have a link to the source of these new hubs?
Hi @sesat,
Unfortunately, I made a purchase to a local seller.
Hi @DavidF,
This motor is for 15s battery. 23Km with 12s battery.
10char
What Range and speed are you getting
Hi @Dirtynunfishing,
The distance was not measured. The speed is up to 23Km on a flat with 12s battery.
Originally, this motor is optimized a 15s battery, so the speed is very low with 12s battery.
Hi @Esk84life ,
This motor is heavy. It is too heavy when applied with four wheels. So i am improving in the direction of weight reduction.
@Martin Very nice experimentations!! How is riding 10 inches vs 8 inches on the street? Can you describe how you make pneumatic tires fit on hoverboard hub motors? What parts and tires should I buy? Any links? Very nice stuff by the way!
Hi @JulienB ,
The feeling of a big tire riding is not good.
It’s good off-road, but not good on regular roads.
My method shoud make wheel hub adapter.
I don’t recommend it.
If you refer to the attached link below, there is a way to install it without a separate adapter.
Hi there! I’m currently in the process of building a mountainboard with the same 10inch motors you first used and I have a few questions if you’re willing to answer ![]()
First of all, did you have to open up the front wheel motors (of your first build) to change the tire?
And second question, how did those tires fit? I found them online and i see they’re 3inch wide while the originals are about 2.1inch wide.
Thank you!
Hi @gardo,
Q1 => No. You can change the tire without opening motor.
It will be hard work. You must use tire remover stick 3ea(green stick on the picture).
Q2 => Most tire possible fit if matched tire’s inner size.
If too much wide tire, very hard work to fit.
Good luck!
