Yay, the big ones are here.
Great for TB110 or other big kegel wheels.
Available HERE
Includes both 8mm and 10mm bearings.
Also more fixed axles with an updated 8mm length.
Available HERE
wooohooo! ordered
Ordered!
How much longer is the 8mm portion now?
That was fast! Got em in 2 days xD
Tolerances on the bearing seat and kegel pins are absolutely perfect, great stuff Kev
I know this may be a little off-topic but what trucks do these fit? (basically, I’m trying to find out where to get extended axel trucks because these are sick)
same place you get the pulleys from?
Available HERE
Arrived today!
Definitely purchasing these and a set of TB 110mm wheels soon.
Are the pulleys with bearings comparable with the 110s and the 220mm hangers as they ship? I’m a little concerned about having enough room for the security of the nut.
Yes they are, they fit perfectly
Perfect, it seems I just found my next pulleys!
The fit and finish of these pulleys is great. Had an issue with not getting the 10mm bearings, I got those and now I need two 10mm spacers on each pulley to make them work. Emailed Kevin this morning about the issue.
Would be nice to get these with abec core!
I can accommodate that
Thx that would be great!
Only 200km on them pulleys =(
Several pins got loose, one even ejected himself thru the core and got lost
They definitely need to be glued in, not just pressed.
Was able to press them back in with sleeve retainer except the lost one lol
Yes evolve uses 5m too. They can be installed on evolve boards with the use of the included 10mm bearing and spacer.
