is the carbon fiber in between the layers, on top or at the bottom?
Top
Yup, topā¦
How many pounds can It hold?
Have you tested itās weight capacity?
Itās been a minute
So far good for about 265 lbs. Havenāt tested higher than that but it still barely flexes even at 265 lbs. Thereās like zero flex.
Bought this deck yesterday from @torqueboards (+fiber enclosure, 12s4p), pretty hyped ! Is there more photos coming ? Also, any information on the deck weight ?
Thanks.
@Edratuom Yeah, weāre working on itā¦ some of the parts are getting done but working on finalizing the enclosure/battery setup.
Waiting on some PCB prototypes but batteries are being worked on too.
Battery PCB looks great PCB will be black not red though.
Decks are almost done but need to test the enclosures as they will be form fitted around the deck.
Might take a bit longer than expected but I want a solid setup overall so will be worth the wait.
Are you doing this on purpose Dexter?
In all seriousness, itās about time someone put this mold to use commercially. Youāll need to stay on top of them about clear coating as Iām sure youāve found out, milky finish is a real issue.
Red looks cool. Was debating on making it red lol.
Iām assuming youāre referring to the deck mold? @Brenternet
Analog only. The cut out is to transport drugs across the border. Why do you think Dexter moved so close to Mexico
Cocaineboardsā¢
what is the size of the power switch hole on the enclosure?
Could look at the switch they provide if itās specified.
yep found it on the website! its 14mm. Good call, thanks mate!
Years of engineering pays off.
Thatās nice
