@torqueboards any pics of the fiber glass enclosure? I already put my order in for one, but not positive what it will look like. Or will it look same as abs one ?
Guess I will try something, I also pmd @BigBen.
Edit: The ESC Hump isnāt even my biggest problem, itās the holes in your enclosure. I get that they fit perfectly with your parts, but talking about water for example: I only have a charge portā¦
What do you mean enough sidewall? To mount a screen?
Edit 2: Arenāt there enough diyāers then that want a āfreshā start with an enclosure?
@subarucasey Iāll post it once we get it finalized.
@Jamie42 Yeah, if enough people want it sure. We can offer it or someone else can. As far as sidewall the sidewall is only about 5-8mm. You can barely mount anything on it. Thatās why that section is a little taller to be able to fit the components.
Just curious, how many poeple youād need?
@Jamie42 If you can get 20 people. We would obviously need an entirely new mold for what youāre asking. But itās doable.
pre-ordered mine! Canāt wait!!!
Testing the deck enclosure but changing a few things to improve and build a more solid setup. This sample isnāt the final version but will be similar - it is a prototype.
Will be pretty sweet! Thereās barely any thickness to the actual enclosure. Because of the cavity itās also real easy to install everything. Also just debating on going with the fiberglass enclosure.
More then enough room to fit the new escs, huge BMS (if you wanted), single stack 12s4p with some space to spare for wires, bluetooth adapters, etc.
What about a 10S5P?
@b264 If you can fit itā¦ You probably can. 650x148x15
But Iād prefer 12s4p or 12s8p more simple/easier less wide.
Havenāt 100% tested but you can/should be able to fit a 20700/21700 12s4p/12s8p with ease also.
@Pedrodemio I did check the cutout and it isnāt 100% flatā¦ It is slightly curved unfortunately. Just FYI.
Hummie was also offering a lifetime warranty on hubs he wouldnāt even make money on soā¦
Love you. Missed this thread somehow. Youāre killing it.
@SeanHacker Yupā¦ unfortunately canāt race to the bottomā¦ We unfortunately need support to continue building upwards.
Iāll be rocking this deck soon.
Goddamn right, donāt worry no one is going to be getting a hummie deck anytime soon anyway
he Said he placed the order already he should be getting them like next month.
@Kellag If only it was on amazonā¦ lol
Not only thatā¦ Iām mostly referring to everything. But thatās a longer storyā¦
@Tamatoa decks should be done within that time frame but the enclosures may be pushed a bit further as weāre trying to make it 100% form fitting and make everything else easy to setup. Itās unfortunate but overall it will be better.
Oh yeah Iām with you donāt worry, Iām on my way to take out hummie for you rn, thatās what a real fan does @Underoath888
Lol I got no funk with hummie. Heās a good catā¦ You can be a true fan and toss those foamies
I still havenāt gotten my set of torqueboards foamies
I still want to get a Hummie deck tho, maybe when @torqueboards finally sells his, people will get rid of theirs.
BTW Got some 74A Iām testing may test 72Aā¦ @Kellag Will try to the end of the earth and will need a video of you burning some foamies.
