Unfortunately I had to cancel my pre-order two weeks ago, being in France VAT + fees could be surprising high depending on luck with customs. I still look forward to see how this deck comes to life.
@torqueboards Can you answer my ticket please ?
That would be beautiful, that shit is expensive. But have it already at home, so got to use it.
Lol the board does ācomeā with grip.
Hexy grip
Sure, but not ON the board.
Preordered. Still gonna want that pic though!
Quick question, whatās the smallest tire size these things fit? 90? 97, 107?
You talking about the double stack 21700 enclosure? Itās thicc so Iād stay around 100mmm. Might be able to get away with 83mm.
@Jamie42 depends if you top mount or drop through. 83mm might fit but I havenāt tried.
Double stack we havenāt finalized yet as weāll need to test. I might want to go 21700 for a double stack so for now itās on the backburner. Waiting to first finalize on the 12s4p setup first.
@torqueboards I would like to use drop-through, would that fit the V3F enclosure on 90 /97mmās?
@Fosterqc Nah I ordered the V3F single stack one. Planning a 12S5P 30Q for it.
Ah I realize now your development of the double stack enclosure hinges on the development of your own 12S8P 21700 battery.
I wasnāt thinking about that before so I see why much time must be taken.
Will a 10S5P fit or only 48 cells?
@torqueboards if you finalized the TB40 model could it be released to help people plan their builds in CAD?
According to my sketches I can fit a 60 cell battery with a unity and flexibms, but that will be very tight.
@Fosterqc Yeah, working on everything fitting perfectly vs things just mashed together. We will most likely start offering complete setups soon.
@b264 10s5p might fit if you can fit it within the size but I havenāt done any calculations or anything as I donāt ride 10S and 5P isnāt as easily scalable. Ex 4P to 8P and 5P to 10P. Iād most likely have to make it much wider. Itās a pretty wide cutout so Iām sure you can make it fit but also our enclosure will be pretty much built for our setup exclusively.
@Fosterqc We wonāt be releasing our cads unfortunately. The way weāre planning our setups you wonāt really need anything else unless you just want to build a DIY with multiple brands or want something more specific.
Here is a tight 10s6p if you can make a custom battery this shape
(VESC 4.12ās shown, you can probably get a smaller makerX dual for better fitment)
How many mm do you take per cell?
Esit: while considering fishpaper and other things making it bigger
@jamie42 all depends if youāre using up all the space or not. If not you can have more fish paper
Can this base plate be used on a Torque boards drop-through deck?
Do the angle adjustment screws touch the deck?
@LEE They look like they might be fine but Iām not 100%. Pretty sure though they will clear.
Hey, I am sold out of all the TB DDās, but if you can get ahold of Ernesto, heās got a bunch!
