3D files / CAD request thread
If a 6485 SKP reacher in 10mm axle is what youre after i can get most of those dims
Anyone got files for mountainboard bindings? MBS or Trampa ones preferably.
The entire 3d model? Or are you just looking for something like the bolt pattern
MBS F5 Binding v17.step (4.7 MB)
MBS F5 Binding with Heelstrap.stl (9.3 MB)
I’ve found these files somewhere on this forum, but I don’t know how accurate they actually are
That looks like the model from my cad dump thread. Its not super accurate since I only made it for a visual aid. If you got any specific dimensions you wanna know then I can probably verify them but I made this model like 2-3 years ago so I don’t remember how accurate things are.
It’s more than enough thanks. Just using them as visual aid as well.
Hi, does anyone have the cad file for a 50xx or 60xx motor shell and stator, ideally below 70mm tall? Thanks!
hi, does anyone have the step file of motor mount for 20x20 truck? Thx!
do you rather it be single part?
or two part?
sorry that is 3+ parts,
this is 2ish part
single part is very beautiful ))
Does anyone have the CAD for the Acedeck NYX Z1 trucks?
Has someone made a case for a dual FSESC 6.9?
Has anyone made a model for a shockpad that would fit on a Trampa wing?
Does anyone have a 3d model of the 3dservisas fatboy mini AT gear drive?
Anyone have a model of the haero bro x apex 2023 deck. Or a file for the shock pads. I was going to design a set but I’m just learning fusion 360 and it would be a whole lot easier if I could work off a deck model.
Has anyone come across a file for an exway wave battery case? Would be good to fit some 21700 in there
Does anyone have a CAD file for 36t Kegel pulley? I’m trying to get some fabricated through a local aluminum company but I don’t have dimensions.
Press fit is preferred if possible^^
I’d like to add my ESC box into the mix.
https://makerworld.com/en/models/625416#profileId-549814
Moondrive Matrix 2 truck mount needed. @moon
