270+ Wide Hangers
Hi, I would like to make another build with a 38’’ kicktail board [1] but, this time, going with a cheaper approach, replacing the 3D Servisas gear drive with a belt drive setup.
[1] Kicktail 38'' | SS Mini gear drive | 10S3P P42A | 2 x Maytech 6374
In the aforementioned build I used the wide 275 3DServisas hangers which were enough to clear the 6’’ wheels.
The Boardnamics BN270 would most likely also work but I’m based in Europe and shipping might be a bit expensive.
Do you know any other alternatives besides 3DServisas and BN270 which are at least 270 wide?
I might sell them.
I also have 270mm DKP trucks if you are interested in.
Which ones are these?
Evolve style just wider and beefier with 10mm axles, to allow to ride 22mm OD and 28mm OD bearings for street and AT wheels.
https://www.instagram.com/p/B_CjSC3qcaz/
