£260 - ALL TERRAIN MOON DRIVES
Depends on the truck. On Trampa/Luna/Apex hangers yes.
Oh and MBS Matrix doesn’t need any inner spacers
I’m on matrix so I think I am good then :grin:
It aint perfect but it works :joy:
Thanks @moon!
Did you post this? Couldn’t find it in the comments section dude
No I’ll get round to it mate
Matrix drives out of stock.
Damn it! Ha I’m never gonna get these drives…
I cant find loctite 638 locally, any other product that would work as well?
Loctite 648 :joy:
I have some knock off red loctite I use on my sprockets which does a very good job and is super strong.
I’d just check what you can get local and give it a try.
If you have a keyway or keyway and grub screw the loctite doesn’t need to be super strong anyway.
:expressionless: :stuck_out_tongue:
I can find red thread locker and possibly even red loctite. The pinions that come with the drives don’t have grub screws unfortunately but it does have a keyway.
If you can find red loctite it should be fine too.
If you can get the original you can look up the data sheet for the specific number online to see if it will fit your needs before you buy.
alright i’ll look around a bit more and do what you suggested. Thanks
just to be sure, JB weld isn’t recommended, is it?
No.
Permatex 64000 is nais
Red lic-tite is holding for me.
:smirk::smirk::smirk:
6 gear drives left :boom:
I am looking at ordering 12.9 black nickel plated bolts which will have good corrosion resistance. Hopefully I can get them with nylon patches so you guys will not need to use any Loctite on the bolts.
I will list M4x10mm bolts in packs of 100 when they are here.
Next batch is 47T spur? :pray:
No, I’ll need to do some testing as I will be trying some more new things.
How long does it take for the next batch to get in?
