I’d try the new exway race tires on this board tbh instead of the kart tires. I highly doubt that you wouldn’t run into serious wheelbite on the kart tires here.
Fair point, I was not looking forward abt extending the heims outward to accommodate for wheelbite problem
But kind of nervous to buy a set of nice rims solely for the exway tires that could just disappear overnight @Dinnye
Fair enough. You could get MBS pro XL rims, those fit the exway tires plus basically every other esk8 tire as well. If i recall it correctly you’d need a 10mm wide spacer/extender for the hubs for the best fitment. I have the files shared somewhere, printed ones outlast the hubs. Just needs to be at least PETG, PLA melts in the sun, I found that out the hard way…
I do have a pair of those skinny glass nylon rockstar 2s I think I saw a printable spacer for them somewhere…could be worth a shot
and bingo https://www.printables.com/model/210213-mbs-hub-spacer
on second though idk if those are it, I need to check when I come back home from this work trip
The nylon hubs are 3.75" only tire ID. You need the specifically the XL version of the alu mbs hubs because they have the 4" tire compatibility as well. I do have spacers designed for those
