You sure? @pookybear claims they are in fact 10mm motor shafts.
I would really like this settled since my friends build depends on it. And it is largely the reason against the haggy drove system. Timo hasn’t answered PM’s or mentions. Maybe @haggyboard.jeff can help?
I went through my pms w timo. Now that I think about it. It might be the D shape. The reason I said 10mm was because I got the motors from @CiscoV, which are 10mm OD w 30mm shaft. I could only find 30mm shaft length w 10mm motors. Damn it. Now I’m getting confused also Here you go:
Haha. I’ve successfully ran 18t pulleys with that drivetrain
some shallow head motor bolts Are needed
Only problem is the heads can be easily stripped and they’re expensive as shit
I just need confirmation from the horses mouth.
Either haggy members need to respond and confirm what the haggy complete comes with, and if we can get 18T pulleys. Then I’ll be happy.
@pookybear it’s not that I don’t trust you. O just want to verify. Trust but verify
I had told you we have tried that system. Although, that kit is pretty damn good for what it is. But It didn’t work as planned for us. I was trying to make sure @Clone200 does not make the same mistake we did. It’s all about ease of getting parts when things break as well as modularity.
