here the link,
8.0信MonHcxujASC微 https://m.tb.cn/h.49by6Dq?sm=14eff7 可裁剪EL冷光片LED发光片冷光板定制异型发光灯片超薄发光板背光
I got a sticker put up on the light penel, also cutted griptape with sticker’s shape.
here the link,
I brought those switch from local electronics stores
You cut out the deck so the light panel would sit flush?
according to that taobao link, the light panel is only 0.3mm thick, its pretty much unoticeable i guess unless u look really close
haven’t cut out the deck, light panel are quite thin…unnoticeable if covered griptape. also it are cuttable, u can cut the light panel into the shape u want to to reduce the noticeable bump.
Yeah the light panel looks think but the connectors look bulky
as long as u can supply anywhere between 3 to 24v, then u can do what he did
there also a huge power adapter to support the light panel .
Respect! Clean, detailed, meaty. Tidy!
Are they Radium mounts? The lighting on that first photo makes them look especially badass.
yep, mate , forgot mention it, it is radium mount. Haha
You can always grind a small pocket into the deck, same for the lip of the panel as long as it’s a clean transition you won’t notice
Super Tidy build I would also like feedback on these motors I want to use them on my flux build.
Why tin and AWG cable instead of copper braid ?
@Ean.esk8 do you think this is the same as yours? 105mmx148mm 12V A6 EL Panel Light Electroluminescent Light Paper Neon Sheet W/ Actuator|Decorative Lamp| - AliExpress
I actually used copper braid in between. just the tin covered it up.
they basically are same as APS 63100, ant innovation is OEM motor factory.
yep, man.
