I’d be interested to see if anyone has used a regular enc just mounted upside down , I have a similar question, I can’t bring myself to use pelican style on a thane board
I use this for my trampa build. Holds a 12s2p 10ah lipo setup.
https://www.jaycar.com.au/sealed-abs-enclosure-240-x-160-x-90mm/p/HB6134
Pelican cases would be the better option though
From a distance that looks awesome. Do you have any closer pictures? Also what battery set up do you have?
Yea it would look shit and really disproportionate haha
I use a 12s6p but my vescs are in there aswell. You can check my build thread or my instagram (check the stories there you can see how I modified it)
This is what I used from amazon. It’s a little over sized so 9P may have fit but it would have been a bit tighter than I really wanted.
12S smart BMS on the front of it. So you could also probably put a 13th row of cells in there if you moved the BMS ontop but I wanted to keep more room above incase I decided to put the ESC or other items in the lid.
Dude! What deck is that?! Loooks soooo niiicccee!!! Also sick skinz. Is this a @Sender job? Can’t wait to see this built.
Building an emtb myself atm, went bottom enclosure because I can’t bring myself to top mount lol (go with what you know). Been watching mtb builds closely lately.
Thanks man! It’s an MBS Pro 97 deck
It had some cosmetic damage on the nose but needed cut anyway so I sent it to Mike and Tim to work their magic. Certainly won’t get any bite on my gear drives now.
I thought it might be. Looks sharp as hell (no pun)! I’m gonna use a comp 95. Hopefully it’ll be a solid deck to build upon. Hadn’t considered needing to modify to prevent bite. Not using gears tho, so might help to make a difference… excited to see this whip in all its glory!! Any recommendations for the hubs? Mine came with twistars which I likely won’t implement. They have the pro version of the rockstar or 5star which I’m considering, but not sure if it’s necessary.
Sorry to derail the thread people!!
I built a Comp 95 for my GF and it works worth the 72T pulleys MBS makes, running Matrix II and 5 Stars
Looks awesome man!
Take the rubber out… Just cut the edge of the seal off where the box sandwiches and you’ll love that extra space.
