12kw beast designed by Revskateboard
Nice suspension!
Very cool!
AWD battery PCB
Race board incoming??
Looks incredible!
AWD Phantom x in 18s configuration.
The best !
One question: is it possible for the Master 110x77mm Extra Wide Precision Hub to come without balance and require adding weight to correct this?
Correct what?
I have two sets of master wheels and they seem pretty balanced in weight, the tolerances are extremely tight. I think if you see balance issues, that’s more about the tube and tire, where you may need to spin balance the tire without the tube, there’s a bunch of YouTube videos on this.
Send link please
Mboard has a good tutorial - https://www.youtube.com/watch?v=6igyRGFyRyU
The 162mm street tires were a bit too low and installed the larger 200mm off road tires. I think it’s a good balance, hopefully has good traction.
Thanks bro ! You have a perfect set of wheels and tires! Congratulations!
Just a warning on the off-road tires, they have good grip till they slip but once it goes, it’s gone. It’s not like the semi slicks.
So, do you recommend buying the 162 ACE CST or some other model to use with the Master wheels?
Good to know, the 162’s feel grippy (haven’t ridden the off road yet) but the tires leave the gearbox close enough that I might bottom out on road buttons. I do love how low the board rides.
162’s are good for race and street cruises but any dirt/gravel I wouldn’t rip em on the phantom.
both tires are really good in their respective environments
I’ve got 30g offsetting my valve stem on one and 15 to 20 on the others. It’s the tube and tyres as mentioned, as I had the same experience running them on MBS xl hubs.
