Motor mount Edit: Not decided yet, but possibly like this 3d printed one. Choice depends on the temperature of the motor. If it is not going to warm up that much, thin plastic mount would work great, such as this one:
Actually i do not trust default motor plate design. Yes, it is robust, but handling belt tension (especially with low teeth motor pulleys) using 4 bolts perpendicular to the tension direction is the nightmare of the engineer.
But your reply makes me thinking about creating the same design as my 3dp, but full-metal. It would be nice, actually
Is a belt drive generally lighter than a hub drive?
Edit: I am looking for hub motors that weigh less than 5 kg and are compatible with cloud wheels or all terrain wheels (something not urethane). However, that seems not possible, I have learned. So I will have to use TB DD; however that thing is very heavy and I want to build a light weight small commuter board too - comparable to the commercial backfire mini.
I don’t believe so because of the pulleys and mount and wheel innards, but I would still prefer a satellite motor configuration anyway. If you used aluminum pulleys and even drilled some holes in them for weight reduction I think you could get close except have a lot more performance.
Well, I would be really happy, if you would find a hill in Moscow that is steeper than 10%. Yes, I can encounter some inclines, but generally not significant.
And yes, Moscow is in Russia, so esk8ing is as legal as being a pedestrian. So hubs still suck in my country
This is definitely not true as stated — a single TB6380 motor on a single drive with a good ESC can haul ass up some hills. (and I’m a fat guy) It’s not the lightest weight thing though, however it’s much lighter than a dual drive.
In context of lightweight and only using a single 5065, yeah hills aren’t going to be its specialty, but it will be able to traverse them. Just not with tons of power. I’ve gone home on a single 5065 many times when there was a failure or other problem, and it will move you around just fine, and even up hills. It just feels very sluggish going up hills and when slamming the brakes hard.
Interesting. Probably you have much more experience with single belt drive setups than I do … I only tried a 110 KV 6384[sic!] 6364 motor from Trampa (advertised as amazing hill climber!") on an Urban Carver board with 7 inch tyres, I think, and a VESC 6+ - that left me very disillusioned, since I could hardly go uphill at all.
10 pound (4540g) is really light and going to be difficult to acheive.
However, I would not skimp on certain things, even if you puts you past the 10lb mark.
I would use high quality cells, maybe a 10S1P of Molicel P42A, even if heavier.
I would also use a satellite single motor configuration as discussed above, even if heavier.
…despite both of those being heavier than the alternatives… …because the longevity and performance improvements will be worth it, imho.
The things I would try to make as light as possible are things like the deck, the wheels, drill holes in anything you can, like pulleys etc, use smaller gauge wire like 14AWG or even 16AWG, no motor sensors (physically remove them), no connectors – solder everything together, basically have no parts that aren’t necessary to make it functional. You could also make the “deck” and the “enclosure” the same piece of custom fiberglass…
121c Aileron + a single loaded unlimited hub on some lightweight skate trucks + a 10S1P P42A pack w/ a daly bms running 25A batt / 40A motor through a single superfoc6.8.
Like @b264 said, 16AWG, and as little of it as possible.
I’m playing around with those, had the same idea, but one of them is completely useless.
Dual Loaded hubs are nice as fuck on the other hand
Their thane sleeves are much better than full size china-thane wheels.
