Hello everyone! I’ve been building and working on li-ion batteries for a while now, assembling, fixing and installing them on esk8’s and ebikes mostly, but recently I got a lot more to work with so my friend and I started a new startup company called American Electric Solutions LLC, we specialize in refurbishing and destribution of unused Li-Ion battery packs and cells from various suppliers.
Right now we got our hands on a huge shipment of battery packs made with 3200 mAh lg mh1’s from mid 2022 that were sitting in storage for about 6 months. Unused We parted out about a third to sell as cells and the rest we will try to sell as is.
This particular listing is for refurbished and unused LG MH1 18650 cells (full specs below). We extract and clean them from unused battery packs. The packs were kept at 50% charge the whole time, some capacity degradation is still expected, but per our policy no more than 5%.
All spot weld marks have been removed, the cells are ready to be assembled in new battery packs.
All cells are tested for performance and capacity and we guarantee 95% capacity on all of them, otherwise you get either a replacement or a refund.
You are getting brand new quality & capacity, for the price of “used” cells which would normally have noticeably decreased capacity.
All orders of 40 cells and over will arrive in free hardened plastic honeycomb style cell holders for 40 cells, with threaded mounting holes and room for bms (see attached photo). These cell holders are free of charge to you, they are worth about $15 each.
Here are the specs:
Brand: LG
Model name(s): LG18650MH1,INR18650MH1,INR18650-MH1,ICR18650MH1
Origin: South Korea
Weight: 49.00 g
Typical Capacity: 3200mAh (at least 95% capacity guaranteed)
Nominal Capcity: 3100mAh
Diameter: 18mm
Length: 65mm
Voltage nominal: 3.6V
Charge voltage cut-off: 4.2V
Discharging cut-off: 2.5V
Standard charge: 2.5 hours
Rapid charge: 2 hours
Watts (charge, max.): 11.253 W
Watts (discharge, max.): 36.3 W
Energy, max.: 11.62 Wh
Maximum charge rate: 3.10 A
Standard charge rate: 1.55 A
Minimum charging temperature: 0.00 °C
Maximum charging temperature: 45.00 °C
Minimum discharge temperature: -20.00 °C
Maximum discharge temperature: 60.00 °C
Storage (less than 1 month): -20 – 60 °C
Storage (less than 3 month): -20 – 45 °C
Storage (less than 1 year): -20 – 20 °C
Max. continuous discharge current: 10.00 A
Peak discharge theoretic, 4 sec: 17.5 A
E-rate (charge, max.): 0.97 E
E-rate (discharge, max.):3.12 E
C-rate (charge, max.): 0.97 C
C-rate (discharge, max.): 3.13 C
Internal impedance: 7 mΩ
Chemical abbreviation: NMC
Cathode: LiNiMnCoO2
Anode: carbon
Remark: Ni-Rich
Shipping USA only for first few weeks to get the word out and build a reputation. Worldwide shipping later, 2-3 weeks max.
Shipping cost:
-Up to 20 cells - $10
-Up to 200 cells - $20
All transactions are made through paypal with tracking, so you either get your package or a refund.
Zelle also accepted.
Here is an in-depth data sheet about the cell, it’s testing and origin.
Be advised, this testing data is from 2015. LG Chemical improved the chemistry of this cell in the last 7 years.
The number of full charge-discharge cycles has increased and cell degradation has decreased.
The link to the review from 2015:
