Well, you can say it makes it less functional if you think critically about it. The filter will cause the current to be consistently under-estimated since a certain percentage of time no current is flowing through the shunt. A low pass filter time averages the current measurement and so it will cause your motor current measurements to be biased.
emmmm reasonable. thinking about remove them.
Looks dope! Is it RGB, or just yellow and black?
just yellow and black.
The display will be driven by the zesc?
Still waiting for this as my >12s dreams. Looks like great work
Woah! What firmware is it using? Modified Vesc6?
A couple of these are exactly what I am looking to get for my scooter. I was going to use some YYK controllers To run higher voltages, but then I would have to move the battery and the rewire everything etc.Just to get them to fit. Looks like I could prob get a pair to fit in the space I have in the deck.
Keep it up brother. When you have these ready for sale I’m down for a couple.
Sweet, ide be down to test one at 18S
You are very talented!
IMU
Much wow for the steady progress
Damn, this looks cool. Black and yellow are great choice
Careful with that stem and connector. Had that and very flimsy.
Looking forward to Raiden7
What size battery you using
