Trampa Spur Gear Drive
About a year of usage. Maintained regularly, there is a bit of damage on one of the motor gears’ teeth. There is a replacement set I used regularly, including it cuz I have no use for it. The tubs have significant pebble impact damage but no crevices, the guards have sustained a bit more damage but those are replaceable.
- Helical gears 1:5.8 gear ratio, that means 10t motor gear to 58t wheel gear.
- Requires trampa machined trucks.
- Requires 8mm keyed motor shaft.
$250:
Litech D596
New and never used. Bought it when getting parts for first build, did not fit. Comes with everything.
$20:
Stack of belts
Since I don’t need these i am just selling the whole stack. All 15mm width. The Powergrips are used, but don’t remember how many miles. Taken from my old Evolve board. All of the HTDs are new.
$10:
Apex Enclosure
New and never used. Its a V1 with the aluminum cover.
$130
GridVision BMS (same as Daly)
A few charges in it. Has always been fused.
$10
Pair of VX1 Remotes
One if the receivers is actually toast.
$60
Oricycle Bike Tail Light
Brand new, went against using it.
$40
Front FreeSk8 mounting brace in black
Ordered wrong lmfao.
$10
MoonEsk8 clamps for unmachined Trampa trucks
Used! Bought these before Moon got the machined truck ones.
$20
MoonEsk8 MBS Matrix II clamps
These don’t fit my set of Matrix II so don’t buy these together unless you plan to grind it down to fitment.
$40
IDEA V7 Belt Drive Kit for Trampa precision trucks
If I remember correctly, these have at least 300 miles on them. Three belts included, 2 are new and one is used.
- 15mm belts
- 15t Steel motor pulley
- 72t Alu hub pulleys
$100
All items are plus shipping.
SOLD
Straps
Used for about a year, has bronze ratchet buckle. Doesn’t come with hardware.
SOLD
Mini Remote
The old reliable for some of you. I never really got to use it as mostly I wanted smart remotes until I got my Puck. Puck is all I use now.
$10
Metr Can Pro
Brand new.
$137
Evolve ESC/Controller/BMS combo
Definitely has a few miles in it. Taken from my old evolve which hasnt seen a ride since I built my DIY.
$50
MBS Matrix II Trucks
Debated keeping these but I really like my tactical light clamps that I got from Kaly. A bit banged up when I was trying to install the Moon clamps. Otherwise new and never ridden.
$140
Assorted Trampa Spring Parts
I know some of you still use these, a couple of the dampas have some wear, orange having the most.
$20
Sealed Angular Contact Bearings
Never used, these come straight from @Kaly. I got them to use for a planned project but I haven’t gotten there. Rather turn them over to the community cuz i know one of you might need them. There are the 10mm.
$10:
