If only those 6380s were 170kv…
There true kv value maybe closer to that. I believe Paul’s top speed was much lower than expected and the consensus was that the kv was much lower than 190
Well the true KV running a fully charged 12s came out to around 160ish kv. With a 2.78 gear ratio and 110s the run 31.50 on the top speed.
You are correct sir!
Hmm if moon drives will work with 22mm shafts, I’ll take em. Let me check.
Are they battle hardened?
Yes please take them
Those are BH from TB, I pulled the can to check, they have epoxy on them but not to a diy BH standard bit enough to on them to check that box. Sorry I did not take pics of that.
Just an fyi they have the correct sensor JST plug so no sponsor adapter needed.
moons recommend a 26mm shaft. Unfortunately that 4mm missing is slightly too much for my comfort level. Glws
I wouldn’t take that gamble either, thanks for looking.
Any takers? My last item I would like to get gone.
