Were you using them with a bearing pressed into the center? I’ve found even with holes that exactly mimic MBS spacing my own gears still end up just slightly off center if I don’t tighten them fully to my wheel with a bearing in the center
Not on my hubba hubs. I have 2 different setup rn between my Hubba hubs and Newbee hubs. Hubba hubs I use a long M4 bolts that goes all the way through. On the Newbee hubs I use the Linnpower plate.
Yeah definitely give it a try with bearings in the center if you can, it makes worlds of difference since having the bearing in the center basically guarantees that the gear itself will spin concentric
