Payment via PP G&S, F&F or Revolut. Shipping worldwide possible, preferably EU. Shipping cost are on the buyer, likewise with PP Fees.
New Riptide Caliber 1 Pivot Cups
Free
Nano Remote and Flipsky VX1
Crashed once with the Nano remote 2019 (not the remotes fault) should still be working. Comes with receiver.
OG VX1 technically works but needs a new power button, i seem to have messed it up with conformal coating. Comes with Receiver and cables.
Free
Mini Remote with New spare case
Works fine. Comes with i believe 2 Receivers (1 guaranteed)
Spare case is in a box somewhere hence no pic
10€
MBS F1 Hook and loop Bindings.
Work fine, just not as good as the f5. Great starter.
Free
Battair Lipo Plugin
Connect them to your 6s Lipo and have a voltage readout via app. Can be left on while charging as it’s a passthrough.
Should still be 2 or 3 Left.
No matter the amount: 5€
“Golden Sample” TB 4.12 VESC.
I call them golden samples as they have survived 12s FOC on a Mountainboard hauling my fat ass through the woods.
Comes with professionally installed heatsink. These are my very first VESCS and were the beginning of my DIY Journey. One has the Battery connector cut off. Not sure what firmware they are on but can be tested before getting shipped.
25€ per piece
OG IDEA Matrix 2 Mounts. The 10mm unbreakable thicccc version.
- everything but one brace has been sprayed with plastidip. some parts are worn off.
- Comes with Crossbeams, one is bent from impact, can easily bent back again.
50€
2x Luxe 12mm Riser
- Not much to say, they are risers.
5€ for the Pair
8x 480mm Belts.
- Most new, some might be slightly used.
12€ for all of them
Box of Threaded inserts.
- Only 3-4 max missing from one size.
5€
SOLD
Wowgo 3 - Hobbywing ESC
- Fully working
- Has the first ever iteration of Turbo.
- Comes with 2 oled screen remotes, one has the turbo mode.
35€
2x TB 6374 190kv
- Purchased December 2018
- Worked when i last used them in 2020
- no Temperature sensor (thanks dex), also uses the small JST plug, adapter is needed
- comes with stock 5.5mm bullets
Important note: previously used on the mtb and thus are quite dusty. One of the retention screws for the shaft broke off
. 100% working otherwise, can bench test for prove upon request. I believe one did make some sounds when spinning, not sure what’s the cause.
40€ each, 65€ combined.
Images
Meepo v2 Motors (Replaceable sleeves)
- A set of Meepo Motors.
- Comes with 3 sleeves total [2 Installed, one spare] Will also come with the hanger to mount them.
- Sensors working.
50€
Random baseplates FREE.
Take them, they are Free
0€ Free, TAKE THEM
2A Charger 42v
Sparked on me once, could’ve been my fault, still works but will be tested again before getting shipped. Comes with barrel connector
Free
1x Turnigy 6374 192kv Motor.
- Has 2 flat spots on the shaft for pulleys grub screws .
- Comes with 3d printed TPU Dust plugs and a PLA printed “fan” attachment.
Can easily be removed if not needed.
50€
