Cleaned that up for you bro considering it was me that sent it off the rails.
no grief… thanks
I’d hug you but that;d be inappropriate…
Seriously though, any idea if either of those Evo enclosures would fit an older 41" Evo?
It was a reply to OP but thanks anyway.
are hugs inappropriate at this point?
Think you need to get @eBoosted and @BigBen in here to answer that one
Summoned you are you enclosure Gods
Psychotiller might. Bigbens probably won’t.
ABS is flexible so lends itself to some contouring. Glass doesn’t but will if your fixings are good enough.
My evo enclosure (eboosted) has some serious gaps on the ends but pulls down with some effort.
Fibre glass will not crack though under reasonable flex. I pulled mine down from 15mm and its been fine for 18 months although it does pop an insert once in a while.
Thanks for tagging Daddy-O. I’ve been wanting to find this out for a while.
Yeah, I might be game to try to make the PT enclosure work if the fiberglass ones don’t fit.
Let Ben chime in when he wakes up because you need Glass. Abs is a cover and thats it.
Bens enclosure is like having a solid skid plate under you. I like that security.
The older evo 41? Like a flytrap or something like that? Those decks are way different and won’t fit an enclosure made for those.
Bummer. Thanks for confirming though. It’s A Green Tree which is similar to the Fly Trap, I think. I guess I’ll just have to get a couple ABS enclosures close to the right size and a heat gun.
Ew, i think I had a little bit of sick come up in my mouth.
That sounds like the spooky evo. I have the same deck waiting to be made into something.
Abs is like the Arby’s of enclosures
Oh, you’re into Kydex. I get it.
Don’t want you to puke on your phone, but if I can’t find a suitable enclosure, I may just have to top mount a box instead. Damn vintage decks. If you come up with something for the 15° tipped 41" Evo variants, let me know!
I’ll stop derailing now.
Well, you can’t spell Arby’s without ABS, so you might be right.
Bump TTT
Bump. Chair is sold.
is the psycotiller enc still avail?
