i will take a set for sure
And maybe some sort of adapter plate for the m1s for those 50mm motors? ,
Currently analyzing 140-150mm options with a 63100 and a gear drive. Seeing what is possible here.
Axles will be the same 50mm exposed, 10mm length.
@b264 Thanks for the input on the clamp. I will give less of an arch to not get in the way.
@glyphiks
Yes an adapter plate can be made that goes between the drive and the motor. Someone remind me of the bolt circle dimension the 50xx motors?
Ok, seeing as we seem to be on a roll here…
145mm TKPs?
Gimme the right grub screws lol, I fucked up and stole the wrong ones from ur shop today. You have my address
I mean 30mm in the cheap spot 25mm if you’re into SK3
If you mean SR TKPs, I am not making any kind of hanger for them. Litigation incoming
Ok.
Turns out 145mm is actually longer than needed for a 63100. A gear drive has plenty of space on it.
As for the clamp thing, I made sure that wouldn’t be a problem.
Final question is,
Is 140mm or 150mm preferred?
Racerstars have 38mm bolt circle.
I think 150 would leave more options for small duals?
Nope, i mean BN TKPs not enough TKP options for esk8
150mm allows for dual M1 drive on 6355 motors…woah
we have a winner
Would be perfect for top mount longboards that look dumb with big wide hangers
Overall a little bit less wide than a typical 10" Caliber.
It is essentially that truck width only with long axles.
What motors dimensions did you use to check this ? Would maytech 6355 sealed motors fit with this setup ? (they are 61mm long) If so, as @glyphiks said, definitely a winner, and i would also take a set.
I made a mistake, 150mm only allows for a max motor length of 52mm on M1 gear drives.
You TEASE
My vote goes to 145mm
planning for single 63100?
I might do a single drive build with an orbiter again, target 5kg lightweight build. These hangars would be great, since they will probably be lighter than Caliber II
