That’s correct. Learned all of this shit from my boy @Tello1969. Sickass builder and now racer
I’ve heard rumors that the latest Vedder tool writes to both VESCs thru canbus… but I have no personal experience in that regard, last time I set up a VESC I had to write to each Vesc separately…
Was that with metr or trampa vesc dong?
Da Dong!
The new VESC-Tool is super convenient to use and is prepared to work seamless with upcoming hardware releases. Everything is fully automated and in consequence the complete setup is now nailed with 3 to 5 clicks only. Setting up a dual or quad drive takes just as long as setting up a single VESC.
These are some of the new features you will benefit from:
- Auto motor detection including sensor detection for all VESCs simultaneously.
- Motor detection in FOC open loop
- automatic and accurate settings for motor (can still be manipulated manually).
- FW updates to all VESCs in one hit
- VESC Rescue via SWD PROG (use a VESC to flash another bricked VESC)
- Configuration of all VESCs in one hit
- Profiles (top speed, current limits, power limits, brake etc.)
- Profiles changeable while actually riding the board (you can’t feel the switching)
- permanent and non permanent profiles
- profiles are written to all VESCs simultaneously and instantly
- Smooth low speed braking capabilities (braking close to stand still)
- Analogue cockpit (speed, power, rpm, duty cycle, current, battery)
- Statistics and estimated range (really accurate now)
- Data from all VESCs is now used to calculate the values
- Board can be given a name
- Communication between remote, phone/tablet and VESCs simultaneously (triangular communication).
- pairing of remote and phone/tablet to VESCs (stops others to interact with your VESC/board).
- new remote features to allow display of values on remote
- The new VESC-Tool is fully prepared to work with the upcoming hardware releases
- The new VESC-Tool will be fully compatible with older hardware like 4.xx
- Support for UAV-CAN (e.g. for multicopters and robots)
- and many more…
Dongle!!. That shit sounds so wrong
if you have (2) esc connected via CANBUS and METR connected to the Master ESC you should be able to write configs to both ESC through MetrPro App. when i do this the app says (very quickly, dont quote me on the order)
Reading Motor Configuration 1
Reading APP Configuration 1
Writing Motor Configuration 1
Writing APP Configuration 1
Reading Motor Configuration 2
Reading APP Configuration 2
Writing Motor Configuration 2
Writing APP Configuration 2
when successful you should see a checkmark next to the mode you have applied
this happend to me too. just left it over night then would not turn on. I sent it over to @ seaboader and it was actually just bricked. try getting it to someone to fix, seaboarder said it was really easy to do.
Im still waiting for my cat to shit out my metr pro
