I could measure it yes, but BKB is in the US. That pretty much kills it.
They will work but need to be filed since the profile of the 218’s is slightly larger than a standard caliber.
I don’t have a good feeling about filing…I basically destroyed a Caliber clamp while filing it. That’s why i’m searching for a new one ^^
Right, but these are also larger than standard caliber, which is why they are so cheap. I’m pretty sure I have trucks w/ the same profile as the tb218 and these mounts fit them perfect, but I don’t have a set of tb218 trucks to measure. Anyway, cluttering this poor mans thread.
Atleast it gets a nice push
i think the tb 218’s are roughly 18.25 x 20.25 mm
I currently use a 3d printed clamp. Usually holds for 30km+ depending on the terrain.
Are those bkb mounts different from the ones I have that are about 6 months old? I checked mine in refrence to the 218’s I just sold and the truck is a decent bit thicker than the mount, would have certainly required modification.
What disaster did i get myself into?
bump
10char
These: (probably can find them cheaper)
with an additional set screw drilled from the rear should do the trick with those TB218 's.
I have oldschool enertion ones ( this model ) which fitted my 218’s.
These work perfectly with TB218 trucks and Calibers
bump
10damons
Thread is currently on halt.
I’m waiting on getting some mounts shipped if the person finds the time.
