If you want a cheap 22mm 36T bolt-on abec pattern wheel pulley, go with this guy. Comes with a free 275-5M-15 belt that’s probably the wrong size and a free 15T motor pulley that’s aluminum and not steel.
edit: nevermind, it’s out of stock and probably won’t ever be stocked again
edit2: I have 3 that have been machined into dual kegel/abec pulleys but I probably won’t sell them and 2 are in use
rolling resistance, axle/hanger space for caliber IIs iirc some motors won’t fit with 15mm but will with 12, belt price is a little less, pulley price is a little less and there usually isn’t much of a lonengevity advantage because belts tend to break due to some event i.e a rock getting into the the system and snapping them rather than long term wear
