Too many unknown variables for us to be able to quantify the damage for any particular pack. All we can say is that the longer it is done, and the higher the voltage, the faster your cells degrade.
If you don’t feel that your packs are dying early then it might not be a (practical) issue you need to worry about.
How long is a pice of string. Once the li-ion cells are charged and you keep holding the voltage at 4.2 it starts to plate the surface this reduces the max current flow and makes the cell heat up faster as well as ruducing the total amp hours this is some thing that happens little by little. Bare in mined that just by charging, discharging, age all degrade the cell (damage) if it didn’t it you be able to use the battery forever but most 18659 have 500ish cycles until thay down to 80% capacity
so the cells don’t mind being cut off at full charging amps? btw, is there a comprehensive battery guide? I’d have lots of questions on the issue, one of them being what does count as a full cycle, when I have about 500 cycles before 80%, does that mean full cycles? totally empty (what’s empty, 3V?) to 4.2V? or do 3 partial charges also count as one full cycle? no manual or website or manufacturer every goes into these subjects in my experience…
I have this small diy UPS consisting of a 3s3p hooked in parallel with our wifi’s 12.2V power supply. It’s like charging the pack without ever disconnecting it from the charger. No fireworks so far after over a year of continous operation.
Not at all. You can interrupt the charging cycle at any time. Packs do not explode if we stop putting energy into the cells.
An incomplete charge means less range though, of course.
Leaving a pack connected to a powered down charger or power supply can cause problems though. It can cause the pack to be slowly discharged and a badly designed power supply or charger could potentially be damaged by this.
Not really, the range of topics could fill bookcases…and do. @Darkie02’s recommendation of checking the datasheet is a great start though.
A full cycle is the discharge of a cell from its rated fully charged voltage (typically 4.20V for standard Li-Ion) down to its low voltage cutoff point (typically 2.5V) equal to the rated capacity of the cell and then back up to its fully charged point, all at a certain temperature and certain charge and discharge rates.
For a 3000mAh cell this means that a discharge of 1500mAh, and then a full full recharge, is 1/2 of a cycle. You would need to do this twice to equal a full cycle.
The rated cycle life of a cell is how many full cycles the cell can do, minimum, before its capacity drops down to the quoted number, typically in the 60%-80% range. If a cell is rated for 500 cycles then theoretically it can do 1000 half cycles.
But we can’t get crazy about these numbers. A single full cycle ages a cell differently than two half cycles. Cycling at different charge and discharge rates and different temps changes the cycle life of the cell.
It can be verrrry hard to compare the cycle life ratings of different cells because of this…these details matter.
The noob questions thread is a great place to ask any questions you might have. Lots of people there willing to help out.
It would take many books to even begin to explain all that is involved.
Whoa…that is a terrible thing to do to a pack.
I have no idea what the safety risk might actually be but those cells are being damaged. I urge you to get a new pack with a BMS.
Not terminating the charge and holding the cells at max voltage for long periods of time can lead to cells over heating and thermal runaway witch is a fire risk.
That terminating the charge is part of the charge proses on every li-ion I have seen and used.
While looking for more info bout the subject matter, I found this video of a dude figuring out how he’d undercharge / float charge his 4s pack. Basically he’s tryin to use li-ion as capacitors.
It got this really intriguing reply down comment section.
It has some merit. Holding Li-ion cells at their 4.20V charging voltage will definitely age them faster. It’s just a lousy thing to do to them.
While holding them at a lower voltage is not a standard procedure, and perhaps not even recommended, it is certainly better than doing it at 4.20V.
There could be a big difference though between continuously charging them at 3.80V and charging them to 3.8V and then letting them self-discharge to perhaps 3.7V or 3.75V before topping them off to 3.8V again.
The latter would be much better for the cells IMO and accomplishes much of what someone might want to do by having their cells always at 3.80V. There’s not much capacity difference between 3.8V and 3.7V.
I guess you can just use a standard CV power supply though for the float charging (once the cells are charged) versus having to use a charger for the occasional topping off of the cells.
