VESC WAND REMOTE soon to arrive from the future
Got the wand after ordered 5 days. Very solid material quality especially compare to my vx2. However, it shut off in the middle of ride. I am guessing it’s because I was going a slightly downhill at about 13mph for about 3minutes so I wasn’t operating it so it shut off because of idle?
I felt a little bit of slow down so I tried to accelerate then I noticed the screen was dark. Luckily I was slow and it was a belt drive board and I was also able to restart the wand and reconnect by pressing a button.
Am I guessing right? @Trampa
It won’t shut down because of no signal input. It would go to sleep if you loose signal for a while.
Where is your NRF dongle located? Anything blocking the signal?
3mins downhill without remote interaction sounds like a very big hill.
Did you check the battery?
I called the “hill” slightly downhill cause it can just maintain a speed of 10 to 13 mph without any input. My receiver is right under my EVO deck wrapped with some foam and electric tape, exactly the same setup as was my flipsky vx2. I’ll do some idle bench testing tomorrow to see if it will turn off again.
Yes I checked battery. I put new ones on before the ride and after the shut off I was able to ride home with it for about 4 miles no problem. When I got home the battery meter on the wand was like 98%.
Or maybe I accidentally pressed button 2 for more than 2 sec without realizing it?
is there a way to show the correct remaining capacity of lipos in the vesc app or now in the Wand? or to change a multiplier or somthing? Currently it is about 20% too high.
Hi,
I got my Wand and the nrf dongle a few days ago, the dongle will not connect to the Vesctool at all.
I use Focboxes HW 410 and firmware 3.61. The dongle is visible and when I try to connect I receive the message the Vesctool can’t read the firmware version and that I should check if the selected port belongs to the Vesc.
Could it be that the dongle needs to be flashed?
Yes, at least try it. It could have slipped through the net?
Check wiring, VCC, GND, Rx to tx, tx to rx.
Id did check the wiring and had to change rx and tx.
But still the same issue.
I tried the dongle on an other Focbox which I didn’t touch since receiving it last year and it worked after flashing it with 3.61.
On my other two Focboxes it still does not work. These two Focboxes came from eskating.eu and Alberto did flash the Ackmaniac firmware on them for me.
Is it possible that just flashing them with the 3.61 firmware isn’t enough? Should I flash the bootloader as well?
It’s running now. I flashed the two Focboxes with the default_no_hw_limits.bin and it worked, after that flashed again with the default.bin.
I don’t know what went wrong the first time using the default.bin, everything looked good in Vesctool and the motordetection setup worked etc.
THX for your help guys!
Did some bench idle testing without problem. So far it’s the favorite among all the remote I have. Probably going to buy another one without gun grip. With vx2 out of presale price I think wand is actually better at value/price. The feel of hold metal vs plastic is so satisfying.
@Trampa
Is anyone experiencing patchy signal? I’m Goofy. Everytime I move my wand more forward or even above my head. It loses signal.
I replicated this a few times by having my board on cruise control at 15km/hr. Then I move my wand just right above my helmet and board starts to slow down and eventually stop.
Is there a way to get better signal? Does this run on 2.4ghz?
Do you have a carbon fiber deck or enclosure?
You should try to re-locate the dongle and try again. Carbon fibre blocks the signal. Upright or sideways also plays a role.
If you hold the wand above your head, bottom side facing up, you could get some connectio issues. I’m usually not that acrobatic while riding, but I’ll give it a try tonight.
I move a lot on my board when I ride. A remote should not restrict my movements just to use it. Maybe the gyro is causing this? It thinks that I fell off the board? Is there a way to turn this off?
Yes, we (also 2 of my friends have this remote) have CF deck (hummie). The intriguing part of this is we have a better and reliable signal w our feather remote than the wand. Same board as well.
One thing I have noticed also is when the last known signal is a throttle input and you loose signal, board keeps applying throttle for what it seems like a few secs before it applies the “fail safe” and/or slows down. This happened twice and I didn’t wanna try to replicate it again :sweat_smile: Could you explain more on how the fail safe works on this remote if there is any? People have asked you about this before the release. I must have missed your answer.
I/we will try to relocate the receiver and update you again. But at this moment, we’re pretty scared on using this remote.
Whoever is in the US that has this remote, could you post some feedback please?
Dang that’s kinda scary :flushed:
What do you have your positive/negative ramping settings at?
POS
  • 0.2
Neg
  • 0.3
