First: what
Second: if you learn the app, it takes seconds, not minutes to change a value on 2 vescs connected over can.
If you don’t know jack shit, you do the wizard and poke an eye out on these forums until you get the courage to go top speed. I assume the 85% value is not that common info yet unfortunately and it does need to be addressed.
Also the app could do with a bit more user friendliness ui, some descriptions for at least complicated values that explain use cases, not just what it changes, and a really necessary tone change from that grey background
@Trampa will the vesc hd support a higher switching frequency?
On vesc 6+ i can hear it faintly at 25khz and only on low battery at 30khz. It almost sounds like a wheel is slowly losing air so it’s quite odd
