Almost reminds me of the ESC that was sold with the promise of a second UART port that would be eventually enabled. Only to find out that it’s traces are wired incorrectly so the ESC is incapable of the secondary port. But only months after you bought it.
It’s a mistical black box feature. Good job we know frank is there to battal agains all them bad company’s over and over again as he stands against than all in a just and fair way.
Buying after Brexit will probably save you money, since UK is one of the countries with the highest VAT in Europe. After Brexshit you will probably be charged you local VAT. It’s in many cases beneficial for the customer.
A.S.S. is not the prime USP, just a bonus that the HW is already prepared to allow a new SW feature to work. The VESC 6 MKV can demonstrate that already with a proprietary motorcontroller SW. At this stage we can not share deeper insights. However, Vedder will make an OS software feature available, so that full torque startup code will be available on github under GPLV3 license.
Except it’s the thing that everyone here is most interested in, so it kind of is.
So it doesn’t need custom hardware to work? Who’s code is this?
Why can’t you share any details? If the project is truly as “free and open source” as it claims to be, then there is no harm in sharing this information. Isn’t the whole point of FOSS to be fully open to collaboration and communication and not having all development hidden behind an iron curtain?
Because of messages like this and no explicit answers to the several questions I am pretty sure there is nothing special ongoing in the VESC HD hardware. Benjamin published the MKV schematics already and on a quick look the only thing that changed is a filter capacitor for the voltage measurements that can be switched on. (https://vesc-project.com/sites/default/files/Benjamin%20Posts/VESC_6_mk5.pdf) And the MKV is also labeled as A.S.S. ready. So the major change is only on the Software side and probably works also fine on other hardware.
Your making some assumptions in regards to my deadline in buying - I’m looking to acquire 20-100 units and I have annual budget to Consume - 2020 budget that is. And futher units in the event of the result of the first order - in this case it’s not VAT
As a buyer with a specific scope and application requirement in mind - asking how a feature (weather or not it’s ready or not) works is critical. Could mean life or death and I’m not talking longboards here.
The size reduction and the claimed specs are quite impressive - one simply would wonder - well whatsthe downside - for hypothetical example if the twin hd were to get 5c warmer than say twin Og focboxes It would not meet the requirement dispite it’s size and output
As a supplier it’s not a strange question for a client to ask, what am I buying and how does it - aka what’s my risk - and will the object in question work for the intended use in which I am looking to procure.
It’s a shame though someone’s getting the budget that’s for sure.
Battery wire broke off while going like 2km/h, DRV errors now on the secondary side
No visible sign of the DRV blowing up, but fault LED is on.
Logic board dead? =(
Anything else I can check?
Probably needs a new DRV if the fault LED is on.
Should be fixable. You can try to swap over power stages and see if the fault still pops up. I think it’s more likeley that its a logic stage issue though.
I did and both logic stages work fine, but one power stage has blown FETs.
Aren’t those available for sale? I only see a replacement logic board in the store.
