If something went wrong with this version of the deck, I’m not sure if I would have continued the project. The flat stainless alone is worth around $350. I didn’t want to make the project public until after the welding and only if it went well. And here we are.
3d servisas newest trucks would look perfect on this board
I wish they didn’t need extra holes in the deck for barrel retainers
With the bracket like in the render it would be perfect though
Is this the same bolt pattern as trampa? Also, it wouldn’t match my rear trucks
More progress. I did all the welding and protection on the 4x 4s6p packs that make up the board’s battery.
The brackets came in and they are gorgeous. 1/4in thick stainless steel should be strong enough.
Wow how was I not following this… Total sickness.
The MRI welder friend seems like a solid person to have around.
Thanks bro! None of this would have even been attempted if I didn’t have him
FINALLY wired up each battery module. They each have an xt90 and a 5 pin connector for balance.
Now I have to create a bms harness to go through the chasis as well as all the wiring for the series connection.
I’m really trying to get it rolling before NYE so I can be nominated for build of the year.
I also finished the series connection and BMS harness as well as the charge port.
No rush, they will be a best build competition next year too
Yes, either way this build is going to be done soon. Everything else left is mechanical ready to install so why not try. Just need someone to nominate me when I finish lol
Dude. Been following this thread. Love this build! I hope you get er done, you’ll defo get my vote. Looking at the pics, I noticed the through holes or your wiring look a bit scary.
Might want to add grommets or some sort of wire protection there and all the other holes wires pass through.
Good luck! I know you can get this done.
Yup, absolutely not leaving it like this. I put all the wires in place so I know how long to cut them.
I’m not on enough to guarantee I’ll make the nomination, but I’m sure it’ll be on there. And I’ll vote ya for sure!
Haha thanks man. I’m hoping to get it done tonight if I can.
If you had trouble drilling stainless, be glad you don’t also have to thread them
Drill press is a nice tool to have.
It’s on its way.
Also I messed with the lights and insulated the floor
I placed most of the parts all together to feel how much it weights and…jesus fucking christ.
