STREET BEAST | 16S10P BAK 45D | Dual 56118 650kv motors | 79/12 Gearing | 240mm Tito Duality Trucks | Tomiboi Odachi V2 | MakerX 2G300
Ok. Back to the drawing board.
How do I build a high speed board with 6485/6495 motors, while respecting their thermal limits?
Due to space constraints in enclosure I’ll have to move to rear top esc box. That opens the door to higher end esc’s. Thinking 2G300. My dual G300 in race board been rock solid thermally never really going above 50C on heavy racing application. I was getting D100S to 60C most rides sometimes touching 70C.
The best setup I had thermally esc and motor wise was the 173kv motors with 67/18 gearing. But I maxed that out at 48mph full throttle and wanted more speed so started experimenting with larger pinions.
I tested 16s 173kv 6485 motors with 125 phase amps 67/22 gearing 175mm tires and it ran the esc hotter. I don’t have much data on this setup because I only had it for a day before the board smashed into pole.
I then tested 16s 205kv 6485 motors with 125 phase amps 67/20 gearing 175mm tires. That ran the esc hot around 60C and as I expected it to be the motors sat around 90C while I was experiencing thermal throttling, temperature cutoff start set at 85C and end at 100C.
I know we are building high power high speed race boards with inrunners, but I’m not ready to go down that route for a street oriented board because it will require more phase amps and therefore pull more battery current and inherently affect range. (I’d like to build a big tire board with huge battery someday and use inrunners with that build to be used in the streets)
So will I benefit from the new Mad esk8 6495 motor? Am I going down an unachievable path?
I let my motors cook way hotter and had no issues for 5 years. I’m super weary of setting the full thermal cutoff. I’d rather my motors be too hot and deal with it than have the esc cut off all power on a hard pull and street face me. Not to mention if the thermistor has a hiccup and throws a high value…
Yes I raised my cut off temps to radium recommended 100c start 115 end day before this happened although it’s very likely not connected to this incident.
My strategy on reachers is to not have sensors connected at all. Didn’t manage to cook any of them yet. Doing short track racing 21S 175KV, 200A phase, on the 6395s. Even a very brief tap on the can burns my finger in summer heat so they must be getting very hot. That said I do have motors in the front configured for 60A phase each so those help in a bit. But I’m still more or less full throttling all the time.
Not taking responsibility if this strategy cooks some motors though…
You are the perfect example, how much these motors can handle without breaking them :joy:
Haha. I’d have to agree with you, and I wanna push them further! Looking like I’ll use the new 6495 from Mad.
I feel like I’m not too far from cooking them though and I’d like to increase battery amps further :rofl: hence the planned upgrade to inrunners during this season
If you go to makerx website it says that d100s is designed for 130kv motors
Lower kv motors have more inductance and less erpm so they are easier for the esc to keep tracking
Also some vescs are better at tracking than others
This is probably the best set up
Maybe you can angle the motors lower so they can get more air
The hotter they get, the more difficult to track
knarly dude
You win the award for most torn up Leatts that I’ve ever seen
Little history, they added that after my D100 blew up on Nothing Fancy
I would consider Spintend’s dual VESC or single 85150. The 85v dual ones are more suited for 16S than the D100S using 100v mosfets. They’re usually good for less motor amps than D100S but more battery amps and if something does happen you can replace just the power or just the logic stage.
Or if you’re thinking of something as big and serious as the 2G300 the Spintend 85250 will save some cash and it is much cheaper to replace one logic or one power stage on one side than a whole 2G300.
I know preventing failure is better than softening the blow to the wallet, but I don’t think there’s anything that never failed.
there is the new VESC labs VESC too. The new stormcore. Ben Vedder speaks highly of it but I’d expect him to given it’s his machine.
This is a problem with 100kv motors. At 10-15km/h with a load of more than 130 phases, they make a sound like this. This does not happen with 128kv motors. In the next season, I will try to adjust the vesc with 100kv again.
I considered that heavily but couldn’t fit it with tight space I was working with. Especially with the ports exiting horizontally instead of vertically like the d100 did.
Good find. Maybe the 205kv is what did it in.
Will try experimenting with angling motors for more airflow, appreciate the recommendation.
I’ve decided I will go rear top esc box with SKP solos v1 along with 175kv 6495 from Mad esk8.
Torn everything down to bare bones, getting ready for rebuild. Bore out hole in the deck for Duality queen pin access.
That QueenPin’s access hole End Grain plywood is just aching for a gloved pinky finger massaging in some CA Glue until it can drink no more.
Just like @BillGordon
I black sharpie’d the hole on nothing fancy. Works really, really well.
Little teaser. Man I hate top boxes they’re so ugly. Was hoping to install box sideways but had clearance issues on spurs. For a $10 box I’ll roll with it for now and look into smaller options. Hoping to have motors in a week :crossed_fingers:
