💩 Shitty DIY and nothing else!
But is it this awkward?
Personal opinion, aesthetically that is the ugliest design ever!!!
ew
Oh lawd
I commend his confidence, but it really does look like shit. Also, what are those rims?
Idk but for reference it’s a Lycaon swift apparently
Somewhere under there
I’d like a side view, to see the full extent of those risers
i see no ahegao, that person needs to up their game
uuv0qjiap7x41
joke’s on you, those proud mounted screws are for hanging a picture frame
Has anyone ever just had enough of redoing a joint because it won’t fit on the end cap. Pretty much just drimmeled the joint and made it work lmao, fits like a glove
Please tell me those are bearing caps, and that there are actually bearings inside there.
flush cutters are your best friend when trying to get over-tinned 8AWG into an XT90
Imagine they used bushings instead of bearings, how weird would that be
There was a bit of solder running on the bottom so I had a bit that fit in between, was able to shave it down, the sides as well. Not sure if a drimel was the best bet but that was the only tool I had that could work :sweat_smile:
this ain’t esk8, but close enough to be an ahegao build?
Was in between Shitty DIY and DIWhy? here, but I am going with shitty. Drill battery powered hub-motor being used to drive a bmx tire with friction.
I guess he wanted a kicktail but not a board with a kicktail.
