Elephant is you the stick is the battery
nailed it
With @nske permission, here is a list of things a beginner *may do
*will absolutley do but i donāt want to discourage you
Please try and avoid doing the below
Also
You are never alone, just give a shout out
Pro tips:
-remember to unscrew your fire alarm from your dorm room before you start (whoops)
-if you fuck up and make a big solder ball, you can always use electrical tape instead of the heatshrink you had on that wire
-lead based solder smells better
Just unsolder it, heat it up again and grab it with pliers and shake it a bit. Then something wonderful will happen.
I tried a single time with my ts100, then went out in search of a soldering station.
I can do 5.5mm with my ts100 with the chunky end but I have a 150 watt gun that makes short work of connector soldering just make sure you use a heat sink block the only useful thing I ever learn from Pavels videos.
Only useful video, not the 3000 videos he did on the trampa wand. No one cares for your $300 remote,you estonian hipster /rant> sorry bill
DO NOT wire wool your tip or use a stanly blade to clean you tips. this will destroy the coating on your tip
use copper cleaning pads and a wet sponge
DO NOT cut the insulation all the way thro you will damage the inner corse making a weak spot
you want to cut it 95% of the way thro and then brake the last part
DO NOT use a wire brush same reason you donāt use wire wool
only use flu suitable for electrical connections other flux has abrasive chemicals that will decrease the quality of your connection over time
Tin your soldering iron before and after every use
only got 1/2 way thro and I canāt watch any more he has the correct tools on the table and not using them
+1
That video is wrong in so many ways
I was like, everyone uses different connectors, and every board seems to need custom everything, butā¦
Thereās one magic trick I cannot master, and that is soldering 10awg into 3.5mm bullets or xt60/mr60. Maybe presoldered mr60 woulnāt be badā¦
Done.
Have you tried cutting a side out of the connector?
You know, āmasterā as in perfect every time with comfort, vs my skill level with this, which is cursing and redoing many times but gething some abominable thing in the end half the time.
Arenāt all xt60/mr60 half cut out already? But one side has a tunnel that makes things difficult?
I meant the full gauge wire onto a XT60.
Simple the cable is too big AWG 10 is the largest size I can get in to a XT90 constantly first time. AWG8 I can get in but itās has no tolerance if the ends flare out the tiniest amount.
XT90 is spec for up to AWG10
MR60 3.5mm is spec for AWG12
Flux and clamps/forceps baby. E Z
Is there a list for this? i would like to add it to my how-to-solder-thread but i donāt know what to search on google
