Talk to me, this freerchobby?
Maybe alien
https://alienpowersystem.com/shop/brushless-motors/c8085-sensored-outrunner-brushless-motor-170kv-6000w/
Choppy choppy is the easy bit, do you have someone to turn down the shaft to 10mm or are you getting a 12mm system?
Think he is getting a 12MM system, chain drive
APS and like @moon said I stay with 12mm shaft. Bigger is better
Seriously, donāt see a big reason to get down to 10mm shaft.
Maybe if you want a super small motor sprocket or gear, like below 8th itās maybe an issue, but besides itās no big deal to get things with 12mm bore.
For now I have sprockets and 20mm htd5m pulleys for the motors.
Hope for some gears from moon one day too
We will see.
Compensation for something?
Yes! I donāt have an expensive big car⦠
What you going to solder with that beast?
Bridges
SANDALS!
Youāre a braver man than I. I generally ride with my motorcycle boots.
Letās not even talk about @longhairedboy though. Pretty sure he barefoots his Ninebot.
I wear birkenstocks 51 weeks a year, I only wear shoes when it gets bellow 15c which is not that often.
I have not lost that much toe skin in crashes so Iām ok with it. The speed is in KPH not mph.
If I want to ride aggressively I will probably put on skate shoes.
This guy
Ok you got me. Itās more like a maybe depending on how hard I plan to push it, the weather and current alcohol level.
I wonder if @janpom can add ācurrent alcohol levelā to Davega
Donāt mind them, I can see they are tethered full hide sandals not flip flops
flip flops are the devils work on a skate but also hilarious, ever had the toe part snap during a foot brake and the flop flip up your leg, hilarity
And a breathalyzer for you lushes
I donāt drink either but a way to measure my caffeine levels from chaining cordatoās would be grand. I go full shakey mad man after 5.
I drink so much coffee I just actually forget to drink water.
Which is terrible because I need to drink more water, always.
typical friday night
https://www.instagram.com/p/BufNowilgWa/
