How did you survive ingress into @b264’s house?
Damn what did you do dude :scream:
First it was the baseplates. Now it’s the hangers! :man_facepalming:
I don’t know the circumstances in this case but i need 2 hands to count all the broken/defect mbs parts i have. I skip the brand entirely if i can. Slowly getting rid of most parts.
Can you name some parts? :thinking:
Rockstar pro bubs
Mbs comp 95 (1/2)
baseplate 2x
tires (~x8)
bearings
f1 bindings
Damn thats a lot indeed. Curious to know what happened to the hubs. I suppose the bearing and tires were just worn down from extended use?
The hubs and tires are wobbly.
the bearings starting clicking after a short while
and the some of bearings didn’t fit inside the hubs.
Hmm okay, for reference my trampa bearings are starting to click now, did at least 1500km on them
My trampa bearings still hold up too.
Fwiw the rockstar pro hubs have been known to be hit or miss on qc for the bearing seat. I’m assuming @xsynatic broke the nylon baseplates that they addressed with a fix not the metal? Their tires are known shit as well, hence the aliexpress and razor tire links everyone throws around.
What was wrong with your bindings and deck though?
Just normal off-road riding in the forrest - maybe the tree-roots over time kill the MBS.
Yes the nylon one cracked where the kingpin sits and the metal baseplate is too wide for the hangar. I had to put an additional ~2mm washer between them to make it fit.
My bindings shed themselves, all the fibers are seperating and the deck is crooked
Can I see the deck? I don’t remember if that one has asymmetrical concave or not.
@rene may I politely ask your weight?
its this one
“The Comp 95 deck features MBS’ new multi-camber profile, and proprietary asymmetric concave”
I meant your deck specifically if you still have it. It might just be how it’s built and you weren’t used to asymmetrical concave?
I am 95kg plus 25kg the board.
oh right. Let me check if i can get a pic where you can see it.
not sure if these are any help.
What i definitely notice is when if slightly lift the front left side, the front left side goes up very easily. If i do it on the front right side nothing happens until i push the whole board up. (if that makes sense?)
No idea if that’s on purpose or not but I see what you’re talking about for sure.
