No idea.
I haven’t even used it or pulled it out of its case In almost a year. Last time that I used it was just to do vesc settings.
That’s bad. I have also a little problem with my display. So I’m feeling with you.
You’re gonna wanna swap the kingpin, they’re only long enough for the haggy bushings. And those are
you’re possibly the meanest most evil spirited woman I have ever met
Lol what just giving him a tip
oh there is that brett person… but he has a certain je n’ais ce quoi, a certain panache and humor your posts lack… you’re just mean
Oh okay
look on this evaluation not as a judgement but a possiblity to use your vast experience and world knowledge for good… don’t choose the darkside Luke… you can give your opinion and help without appearing to be a trainwreck…
just my opinion… I thought was wrong once…
but I was mistaken…
Bro are you fucking smoking crack
nah it’s a hybrid mix of unicorn pussy and common sense… it allows me to see clearly and typoe poorly
Get some sleep kiddo
Is this a carbon evolve cut up to be used as a enclouser on a redember?
Nothing is sacred. Correct. Fancy enclosure for a fancy deck.
Thats fucking incredible
Goddamn, that has gotta be the most expensive enclosure going
Well done sir.
I was in a rut. This needed to happen, also I can fit 14ah lipos in there. The escs will fit with router help.
Wear a mask, that carbon dust is nasty.
I’m glad this has happened, pretty keen to see where it goes
Going to cut on actual deck in afternoon. If it feels solid, I’ll decide between 4 220kv motors in rear and a front pair of 240kv up front with 14ah @ 12s feeding 3 unities (will need to hand grind out triangular motor mounts for duals on each rear wheel . )
Or I could be basic and make space for typical 4wd and 28ah of lipo punch.
If the redember came in carbon fiber, I’d start saving for trampa 75/300s and work out 14s or 13s 4wd on 6384/6389 cans.
I love SR RKPs…I’ve been thinking about a drive gear kit this upcoming season. This setup is badass bruh.
