22x12 bearings are only 18$/piece, so 18x8= 144$
Do your baseplates click and clack too?
W e a r -a- H e l m e t
Ready to start putting in the electronics soon Had to take care of my wheel bite turns out the kingpin was too long.
In what way? Iāve ridden it all of a half mile without power just to test the ride. I did notice a little click but I though it might just be the motors rotating. This is my first powered board so these are new noises to me. If it is the baseplates I suspect itās because thereās only 1 bolt holding it in position allowing a little rattle. Also I donāt like that these plates add height based on position because now my front at 50 degrees is noticeable higher than the rear at 35.
Yeah itās the rattling I was talking about
this is why typically on normal flat decks I only run an adjustable base plate in the rear so you can just use risers to make the front the same as the rear.
50Ā° base plates are readily available.
I think itās the plates. When I have the board flipped over you can jiggle them just slightly. When you are riding with weight on it they seems to sit just fine. Itās not the best adjustable plate design but as far as I know itās the only option for the DD hangars. Iād like a cutaway on the sides for wires and a double bolt design for piece of mind. They are pretty though.
Thatās actually a good idea. I have the original 50 baseplates that came with my DDS. I might give that a try thanks.
Obviously made for the Canadian market.
Ive found that an adjustable baseplate dropped through and a non adjustable baseplate top mounted make a flat deck.
What size switchblade is that?
jesus @mmaner , and I thought I was going to be cool skating with wee man and knoxville. Show off. Dick
What cables are you using as an extension to that external pack?
maybe next iteration will have gas pedals like the Kaly
Just a Y cable to serial my 2 6S packs and a 12 AWG cable. This way I can either mount my batteries inside the box or carry them in my backpack. The extra lead in the box is just so when I bail it doesnāt pull the plug to the side. I can also use charge and ride if I use both a box battery and a backpack battery. This is my charging setup
Seriously dude, how many decks do you own?
All upā¦ about 40
Wowā¦
We have 40 here who has more? That must be some forum record.
