Theyāre not for me, I donāt even care for tomatoes in that form.
I was wondering what your reaction would be.
Well thatās dole I need to know then
atleast i know now that i can reuse those surf rodz shoulder bolts if this ever happens to me
jokes aside, this looks rather disturbing
Fak u beat me to it.
Looks super disturbing manā¦ Also like a shoulder bolt, yeah i wonder if its long enough for press fit pulleys
Iām not really sure on that one dude. The only info I have isā¦
āConstant current when turned on is around 25A. 60A for 60 seconds, and 120A for around 10 seconds. So more than enough for any Esk8 I think. Precharging is around 400ms and this thing can precharge up to 0.1Farads of ESC capacitors in this time. The normal Vesc has 0.002 Farads, so youāll be on the safe side.ā
Haha
The surgeon did a great job. Iām walking perfectly now.
What split?
If you go with B, I want A. It kinda looks like a mini LY battleaxe to me, so I could build a cruiser and a long deck matching.
If it helps you, it helps me man. Iāll get it setup on the hosoi and as long as I donāt hate it for some odd reason, Iāll message you about the backup.
is this motor on your rear truck? if so you should probably reverse those angled risers and dewedge that rear with the already wedged deck or itās gonna ride wobbly.
@Skatardude10 Yes the motor is on the rear truck but the risers arenāt angled. Its just reflection from the deck that seems like angled risers. This board is ment to be used in city with carvy roads so no big deal if it will not handle higher speed. And if it will be a problem I will do a angled risers for a rear truck as you suggest;)
Hi dude, the same for the front truck, otherwise the riding expierence will be just horrible because your board will just stear if you lean in for turns. You have to dewedge the front truck to the opposite direction, then you have a chance to enjoy riding.
peace
So after a few rides with a nano-x of all remotes, I think the unity is NOT to blame. Instead, blame may lie with the receiver I purchased from hobby king. Ive had no issues using the gt2b remote on my other board but it uses the flysky receiver, not the hobby king one.
Is that some high end flux for soldering?
eggzakery!
Itās what happens to FLUX when you forget itās in your pocket at work(sux)
hahahahaha
I like your build, I suggest you to reinforce the board, trucks are positioned at a weak torsion spot (most likely to break the the wood under high stress), so you have to make that board more solid for safety reasons.
Very jealous of the people in legal countries, canāt wait to be able to go to a store and buy edibles
@Santino I have this in my mind. I will see how it will behave. If the desk will be so week I will put few layer of CF on them. This is just a prototype for some clarification where I used components I already had. If I will like it I will do final board on 100% where almost everything will be different just concept will stay.
