@moon How many euros
Around 250 euros
@moon where have you been all my life ?
@glyphiks what kind of spot welder is that! Seems like a pretty good intro spot welder.
@Darklinks sick helmetā¦whether or not itās a lacroix doesnt matter. I want one lol
These paint stripping disks are worth their weight in gold.
The deck looks nice too ![]()
This thing was kind of a pain, lol. Routed out the Hummie deck a bit more for a bigger battery and reinforced the cutout with FG, routed front channels and laid some 18ga wire for headlights, and skinned the main bottom in CF for even more robustness and sex appeal. The top is pretty dope too.
@rich What purpose do you have for that 120 mm case fans, beside motor cooling?
They are only 80mm
This is the last try to heal my depression.
The 6384 motors overheat after 10-15 minutes and need a break. The previous SK8 overheat (100°C) after 20-30 minutes. Iām talking about flat terrain and outside temp 25-30°C. I have a fresh battery for long range and canāt ride long, so annoying.
I think we should come up with a water cooling spray or similar solution
BTW, if your solution works, I need details
They looked like 120ās. No noctua fans(austrian quality)
My motor doesnāt overheat, because my mount and the truck are working as a big heatsink.
Exactly what I gonna try now
. Spray of natural water and dirt.
It rained the whole day and I go for a dirty evening ride now (without the fans). Itās only 21°C so Iām curious how long it takes until the motors cook.
My mount gets hot as well, I donāt know the melting point of POM (housing and gear) but that canāt be good.
If the fans doesnāt help Iāll switch back to the closed Maytech, they didnāt overheat last summer afaik but they were not reliable for me, had a couple.
Itās quite high. 175 °C actually. Klaus and I will update you asap, when we have our builds finished and working and running with the maytech ones.
The hummie special. Literally every one of those mods appeals to me.
I need to find me a hummie deck asap and get it to you
@Kingdom421 Do you have a build thread to that? You are using drill batteries?
I havenāt made one yet because this is just for fun. The board ill be doing the build thread on will be coming Monday. But ive been using drill batteries since i started.
I want that board build
i have atleast 20x 20vmax battery packs I could use for this sort of thing⦠you must push forward and make this build thread a reality
How would you configure the vescs to use drill batteries?
Im still dialing everything up. The batteries add up to a 10s2p i believe so i go from that. My next thread will include the Power tool battery build also.
How did you get around the amp draw? Wouldnt the bms inside the pack limit what you need to pull? And for that matter how do you know how many amps are available? Guesswork?
