So that means you can carry 66 g more toast for the poast
Niiiiice!!. What CPU do you have? Do you like that 240 AIO?
Sag on 16s5p is surprising to me. What cells does your battery have? What are your amps and battery settings?
āThere are no mistakes in fiberglass, only more sandingā
Thanks! I have an older Ryzen 2600X and so far so goodā¦my main reason for going AIO was that having the PC exposed like that was going to attract dust and Iād rather clean a radiator than disassemble an air cooler to clean up all the fins. Performance wise I havenāt noticed the difference, but itās not a super powerful CPU anyways.
Only gripe I have is that my motherboard doesnāt have ARGB headers and in order to control the LEDs I had to buy the stupidly expensive Commander pro from Corsair and use the stupid iCue software
Yep
first time fiberglassing. Few air bubbles has caused some voids to form, so ive ordered more fibreglass and will patch them up.
Thatās how itās done ![]()
4wd 50 motor 15 battery up front on 6355ās and 100 motor 45 battery in the rear. Its running square wave in the rear, Iām going to try it again on foc hoping it will be a little more efficient. This was t-racing mind you, which is about as hard on a board as you can be. Theyāre p42 cells. This setup needs closer to 150 amps total.
@Savage1 made this concept. importantly it keeps the clamping separate from the mounting holes. so clamping doesnāt fight against the mounting bolts.
so big it canāt keep straight. ⦠![]()
Smort
That looks great and would definitely be a bit better because the clamping does want to shift the holes ever so slightly.
Ya, itās 2 pieces.
Thatās odd. 16s5p p42a should have no problems pushing 150a. Those are good cells and 5p is basically 225a discharge. Maybe youāre pushing it super hard and experiencing something Iām unfamiliar with.
Are you sure itās sag and not not thermal throttling from hot esc or motors?
Running p42a much above 20a should expect some good sag.
The 45a rating is bullshit.
I could just be fat ![]()
Nah Iām used to seeing 6 or 7v sag even on my 12s5p p42 2wd. That oneās running 120 battery amps total but 4wd pushes it that much harder.
16s8p will do the trick Iām sure.
I keep eating shit man
Ride slower.
IMHO itās more fun to ride slower and not take a spill, than it is to be a speed demon and have occasional wipeouts.
I was only going like 15 in this video, was just on a board I wasnāt familiar with and fell weird so I couldnāt roll out of it.
How the hell did it flip like that?
