Iv got a set of these drives begging to get these wheels on them will definitely need to grab an adapter aswell
No problem just dm me and we can add them to your order
almost 3 years later
UPDATE
Radium wheels are finally ready and in stock!!
What a mission that was
I had no idea making wheels with rubber would be that hard!
I personally think it was worth it though, I love just being able to do anything on these wheels - high speed, hard carving, racing, offroad, no punctures or chunking and super long lifespan. But I’m so keen to see what you guys think.
And yes, we triple checked the spelling…
Any plans to establish a shipping hub in the US? I ask because I recall you mentioned a plan to ship Radium Reachers from within the US. Would love to avoid $60 shipping.
I’m also in for this part
Right now motors are on sale 10% off and free shipping. I’m in the US also.
You are right about the motors shipping free from CA. The website indicates that the wheels ship from China for the cost of $60.
Yea I wish it wasn’t so much for shipping but I do hella want em for my matrix 2
I will def need these and offer my services across a pothole ridden winter in London riding and testing the adapters .
I’ve been looking forward to getting a set of these with m1 adapters being definitive icing on the cake
I’ll dm/pm you
In talks with Mboards! Might not be for this batch though as we’re running low on stock already.
Not a bad problem to have! Psyched for ya’ll, you’re doing cool stuff
Did a 10 mile test ride and the wheels were great! I’ve always wanted thane (or thane-like) wheels on a MTB style deck but it was challenging without 28mm bearings.
Quick question @Tony_Stark
Are you supposed to use 2 bearings on the inner side of the wheel (2 inside, 1 outside, 3 bearings total)? I ended up running 3 bearings for rear wheels with the pulleys.
Looks so good🔥
The wheels are designed for 2 bearings but technically you’re just using an extra bearing as a spacer which I see nothing wrong with.
So close to buying a set for myself, but I can’t stomach $108 shipping ![]()
Hoping for some mboards stock soonish ![]()
Are the other three items in your cart bricks? ![]()
We aren’t that far apart relatively speaking and my shipping is only half that even with bearings and pulleys.
Just updated our shipping rates, check again.
A set of wheels with the box is 3.2kg, and the next shipping rate after 3.5kg was 7kg hence the huge jump after adding only 0.3kg of anything.
I’ve just added another bracket for up to 4.5kg to account for more accessories.
Shopify is a PITA with shipping setup ![]()
Try something else like ShipStation or ShipNerd
The switch to 28mm bearings and a new pulley pattern sounds like a smart move, addressing both performance and durability issues. It’s great to see the focus shift to compatibility with higher-performance boards like the Lacroix Nazare while simplifying axle variations for the Mach1 series. Bigger bearings and a revamped pulley system should definitely improve reliability and lifespan. Looking forward to seeing how the new SR125 system performs in action!
Just ordered mine! Can’t wait to try them out!
Yep and let me tell you it’s sooo good not having to worry about bearings and axle fatigue anymore. Less things on the back of my mind means I get to enjoy the ride a lot more.
Plus the SR125 just put too much force into 8mm axles and 22mm bearings. I’ve thought of some ways to do a Kegal core variant but people are just going to break axles and blow out bearings if we sell them.
