ok ![]()
ok ![]()
Our pulleys are made from steel for a long lifespan with black electroplating to stop rust, and have M5 grub screws to prevent screw stripping nightmares😬
can’t thumbs up more, this need to be more common
Discontinued sorry!
They’ll be in-stock on the second Tuesday of next week?
4 x gear drives please and thank you
that would require a change in design for the R6 trucks ![]()
Next year man😁 We’re only focusing on rwd though.
Lets gooooooooo
Been 2 weeks lol @Tony_Stark
trucks!
Thank you. Just got back from China yesterday. Still sleep deprived but basically we’re taking a slightly different design direction with a hub and interchangeable tyres. Expecting first prototypes to begin testing in about 3 weeks.
The main difficulty has been around the foam. We could use similar foam to the BRP wheels but it will not survive street conditions in small wheels. And the high performance foam doesn’t bond to rubber. If it wasn’t for the foam these wheels would be on the website a long time ago😅
Will keep everyone posted when the new prototypes come in. I know the wait is painful but production tooling is expensive so we want to spend the time to get these wheels right from the get go.
We call them Radium motors because I spent hundreds of hours refining them ![]()
Now we’ve created a Lacroix edition designed to be a direct replacement for the stock 6389 motors:
Does that mean the new hub will seat 28mm bearings?
Now you’re making a couple changes any plans at all for a larger diameter option in the future? 150mm?
Nope still kegel pattern. But it does mean there is more design flexibility to make alternate hubs ![]()
Yes planned but one step at a time. Its much harder to make a large wheel light weight so learning from the smaller size first.
