I’ll chase it up.
The pre-order batch of motors is shipping to us from the factory in the next few days!
I had them run a dyno test on one of the 245kv from this batch at 48V so there is a benchmark for the performance upgrades we have planned in future.
Even I was surprised with nearly 8.4kw in and still 73% of that converted to power at the shaft!
Assuming you keep the motor at a reasonable temperature, could you actually feed it the 8400w?
Not saying it’d be easy keeping things cool. Assuming the lost power all goes to heat, that’s 2000w! Pretty much an electric kettle.
Well it was fed that much power on the dyno. You obviously wouldn’t want to run that continuously haha the cooling system cant dissipate 2kw of heat of course. But I’m pretty happy with the fact that you can dump bulk power into these little guys and instead of saturating it puts out the power at the shaft. It means you can run really high phase amps to get the punch and set the battery amps to as high as you can go without overheating with your setup, riding style and weather
So after many long email exchanges with Charles from Lacroix the gist is basically that they haven’t investigated what might be causing Stormcore to not work properly with higher relative kv setups, and that there are so many variables affecting FOC performance that its hard for them to say why its not working. He recommended to use “the newest detection tools offered in fw5.3” for better results, but I’m not sure what exactly he meant by that. Maybe there are some new motor detection methods in latest official firmware?
He also basically said that they spent a lot of time fine tuning settings to get the stormcore + Lacroix 6389 motors working really well together and anything other than that they can’t really help with because of the amount of time required to investigate.
Motor detection in each version works slightly different based on the patch notes.
Ie if you run detection in 5.2 vs 5.3 the values will be pretty different.
Maybe someone smarter than me can explain the differences.
@Deodand says 5.3 has been the bees knees in another thread for the stormcore, vs what most people on the forum have seen on their applications.
Thanks! I was working with Charles troubleshooting the intermittent braking hesitations at mid-higher speeds on my LSSS with the stock 130kv 6389 motors on-off for 2 weeks.
I was experiencing on 5.2 so tried upgrading to 5.3. Same thing but with Charles guidance tried reverting back to 5.2 and lowering max current rate from 75A to 60A.
At that point I felt it might be a motor issue so taking a chance ordering the Radium 6485 138kv motors to rule out a motor issue.
Duncan mentioning experiencing something similar on his setup using the Stormcore 100D kinda made me worried.
I don’t mean to hijack but I’m still looking forward to receiving the Radiums though!
Appreciate the feedback
Finally some data ![]()
I’d have to admit I was expecting worse, 80%+ over a pretty broad RPM range. Looks promising ![]()
Too bad I missed out on the pre-order!
I see you are out of 205kv motors, would 245kv motors on a stormcore 60D+ be a reasonable pairing?
Unfortunately there is a risk that 12S 245kv on Stormcore will have issues based on what I’ve seen with Duncan and Morgans builds. It could probably be addressed with settings but could be a rabbit hole
You think 205kv would fare better? When will 205kv be available again? If I ordered now would they ship by the end of June with the next batch?
Yeah 205kv 12S will work fine on the Stormcore’s. Unfortunately we may not have more for another couple of months. I’m still deciding whether to do another batch of the current version, or to wait a bit longer and commission the new upgrades planned for it, in which case it will be a better motor again but possibly wont have stock for 3-4 months
What are the upgrades planned?
I will share more about it later, but it will finally be Radium only updates now that we can afford the order quantity needed
Let me know if you end up with any more 205kvs to sell— new upgrades sound great, but I plan to complete my first build over the summer so I sorta need the hardware soon.
Maybe you can have the pair I signed up for. I’m having 2nd thoughts now that new ESCs and drivetrains are around the corner. (i.e. I might need a different KV than the 205 I ordered, and I’m fine with waiting a few months for the next batch)
Any idea how long until the motors are shipped now the pre-order period is over?
1-2 weeks🤙
They’re here!![]()
They wont all ship immediately as the QC and packaging takes a while but wont be too long.
If you ordered them with 30mm mounting adapters those unfortunately are still about 2 weeks away. Sorry for the delay there
Oh man I ordered the adapters too ![]()
Thanks for the update!
