Noticed quicker acceleration while holding water bottle?
Using my motors?
jet engine, duh
that’s not more acceleration until you hit the limit that you are at max lean.
so for the same input force, ie what our boards can give us now. that we can already balance without a water bottle. you don’t get more acceleration you get less due to increased mass.
All i’m saying is in a 1/4mile drag race, a counterweight would likely be an advantage…
Is that why these drag racers are long?
https://www.summitracing.com/parts/hsd-c-014e
Is this another solution looking for a problem?
Huh
I ignored it in my verbal explanation, not the mathematical one
90kg Counterweight:
Center of Mass
((90 * 0)+(100 * 1))/(90+100) = 0.5263m
^Center of mass is 0.5263m from Counterweight
Torque from counterweight:
90kg * 9.8m/s^2 * 0.5263m = 464.19Nm torque from counterweight
Force from car:
464.19Nm / 0.5m = 928.38 N force from car
Acceleration from force & mass:
928.38N / (90kg + 100kg) = 4.8862m/s^2acceleration
100kg Counterweight:
Center of Mass
((100 * 0)+(100 * 1))/(100+100) = 0.5m
^Center of mass is 0.5m from Counterweight
100kg * 9.8m/s^2 * 0.5m = 490Nm torque from counterweight
Force from car:
490Nm / 0.5m = 980 N force from car
980N / (100kg + 100kg) = 4.9m/s^2 acceleration
110kg Counterweight:
Center of Mass
((110 * 0)+(100 * 1))/(110+100) = 0.476m
^Center of mass is 0.476m from Counterweight
110kg * 9.8m/s^2 * 0.476m = 513.128Nm torque from counterweight
Force from car:
513.128Nm / 0.5m = 1026.25 N force from car
1026.25N / (110kg + 100kg) = 4.88m/s^2acceleration
GPT4 is really impressive wow
Can you please explain what you are going on about in plain English.
20 word limit
When you’ve reached your lean limit, apply more thrust by using a counterweight. More acceleration.
Push thumb wheel with thumb
I don’t understand how a counterweight adds thrust, what is it pushing against?
Who is reaching their lean limit?
The force from the board is off axis with your center of mass. This generates a backwards tilting torque. Adding a forward ballast mass counteracts this torque.
@Flyboy’s leg throttle would be good for this discussion. Lean forward board goes faster
I think @ross_forp’s point is that if you’re falling off the back of your board, adding a counterweight to the front will prevent this?
However, he neglects that falling off the back of the board isn’t a problem any of us have(and thus isn’t a limitation)
Around what axis does this torque apply?
